Portable Display With Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 11:13 PM   #1
Portable display with outlets
My wife wants me to build her a portable display with built in outlets. She sells electric scent warmers and some of them are plug ins (think like the glade ones) I am just trying to figure out how to wire up the electrical (a diagram would be great) she would probably want 3 outlets. THANKS in advance for any advice you can give.
MikeB78 is offline   Reply With Quote
Old 03-19-2011, 11:15 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
How about you draw up some sort of display that you and she have in mind and we'll tell you the best way to put in the electrical for it?
Old 03-19-2011, 11:27 PM   #3
Something like this
Hope that works trying to do this from my cell phone!
Old 03-20-2011, 11:46 AM   #4
Rewards Points: 58
Put them on GFCI for sure. I would have reservations regarding the how you plug this thing in? What are you planning for the cord and plug?
Old 03-20-2011, 01:57 PM   #5
nap
You talking to me?
nap's Avatar
Ya, that was great mike. Now, what are you looking for? What you have there seems to be quite simple. Either the backside would have to be enclosed or each individual recep would have to be in an approved box such as an "old work" box. The enclosed back would be simpler.
Quite simply, a black #12 wire from each "hot" terminal "daisy chained" to each of the other hot terminals on each of the other receptacles. A white #12 wire for the "neutral" and green #12 wire "ground". GFCI protection wouldn't be a bad idea. If you do that, use just one and feed from the load side of that GFCI to the other receps.
To feed the GFCI recep, I would use a pre-made 6' whip with a plug on the end. Use a "cord grip" or "strain relief" where the whip passes through the back side of the box. If you want or need to incorporate a switch in the circuit, that would be easy enough.
Old 06-24-2012, 05:48 PM   #6
Originally Posted by MikeB78 View Post
Something like this
designed2 is offline   Reply With Quote
Old 06-24-2012, 05:53 PM   #7
portable display with outlets
Originally Posted by designed2 View Post
electrical dislpay box enclosed to display electrial warmer and plug in candlesI sell Scentsy warmers and need an electrical diplay to show my warmers You can email me at designed2@comcast,net thankyou
Old 06-24-2012, 05:54 PM   #8
display box
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
do I need GFI for all kitchen counter outlets DanDaMan Electrical 2 03-06-2011 07:33 AM
bathrooms and outdoor outlets not working maybecalifornia Electrical 1 03-04-2011 07:24 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 09:37 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
