Porch Rewire - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 01:49 PM   #1
porch rewire
putting up two 4 foot sections of track lighting and i have 4 plug ends can the plug ends and the lighting be hooked together or is it better to seperate them? what is the code
scottekilmer is offline   Reply With Quote
Old 02-05-2011, 03:01 PM   #2
Master Electrician
Rewards Points: 3,768
Is a "plug end" a receptacle?
brric is online now   Reply With Quote
Old 02-05-2011, 03:03 PM   #3
Electrical Supplier
Rewards Points: 150
Probably referencing the "Live Ends" or "Feeds"
What do you mean by "hook together"
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 02-05-2011, 07:36 PM   #4
yes receptical
Old 02-05-2011, 07:48 PM   #5
can they be in the same circuit or do they need to be seperate
Old 02-05-2011, 07:53 PM   #6
Electrician
Rewards Points: 780
You can join the two 4' pieces together and make an 8' section if you have a coupling for the track. Then you could put one feed end on one end and power up all 8' on one circuit.
This is done all the time, a few months ago I put up a track that was almost 250' long, there was 5 or 6 circuits in that one track but if you look at it, its 250' of track lighting.
darren is online now   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
scottekilmer (02-05-2011)
Old 02-05-2011, 09:30 PM   #7
Master Electrician
They can be on the same circuit.
The Following User Says Thank You to brric For This Useful Post:
scottekilmer (02-06-2011)
Adding to Concrete Porch + Steps? 99altrade Building & Construction 8 08-01-2011 01:14 PM
Porch has shifted on a house I am considering buying. Need advice ryanclemson Building & Construction 4 01-31-2011 09:30 PM
Replacing Porch Columns mcwolfe6 Building & Construction 8 05-12-2010 07:51 PM
How to Winterize Porch subdude Remodeling 0 02-04-2010 10:00 PM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 07:54 AM
