Porch Light Suddenly Doesn't Work - Electrical - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 04:02 PM   #1
211
Rewards Points: 49
Porch light suddenly doesn't work
So I have this porch light that had burned out its bulb quite a while ago (sometime during the summer). At the time I never replaced it because the days were so long and we never get visitors after dark anyway.
Well now it's dark by 5:30 and a porch light would be nice to have.
Here's the deal though. I put a bulb in the outlet and nothing...
No light when I flipped the switch.
I unscrewed the bulb and checked for AC voltage inside the bulb's socket and got nothing. No breakers appear to be tripped and the only GFCI outlets we have are in the bathroom and they're both fine.
Where do I even start troubleshooting this? I think it's pretty unlikely that the switch went bad. ...or is it?
211 is offline   Reply With Quote
Old 12-15-2011, 04:20 PM   #2
How old is your house?
Nearly every house has an outdoor outlet with a GFCI. Double check those before you get too far into it.
fuzzball03 is offline   Reply With Quote
Old 12-15-2011, 04:24 PM   #3
211
Rewards Points: 49
early 70's built (71 IIRC).
The only GFCI outlets were ones I installed. We only have one outside outlet and it is not GFCI
Old 12-15-2011, 04:28 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,608
Why would a porch light,
be on the same circuit as an outdoor outlet ?
I thought lights and outlets usually have seperate breakers ?
dmxtothemax is offline   Reply With Quote
Old 12-15-2011, 04:29 PM   #5
211
Rewards Points: 49
Not this house...
I've got breakers that kill the kitchen lights when the vacuum is plugged into the bedroom hallway .
Old 12-15-2011, 04:37 PM   #6
Julius793's Avatar
First open the fixure check for voltage if there is none go back to the switch and check for voltage and just work your way backwards. Btw switches go bad all the time
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 12-15-2011, 04:41 PM   #7
Turn off the breaker first !
Open up the light fixture,
Have a look at the wires,
note where they go,
If it all looks good and safe,
turn on breaker,
and carefully test for power.
What are the results ?
Old 12-15-2011, 08:04 PM   #8
Originally Posted by powerfactor View Post
how do I know which breaker to turn off?
Are the breakers not marked ?
If not you might have to follow the cable !
Old 12-15-2011, 08:08 PM   #9
In that case, follow these instructions: http://www.youtube.com/watch?feature...CbCSM_4#t=103s
ExpFist is offline   Reply With Quote
Old 12-16-2011, 05:52 AM   #10
DIY staff
Rewards Points: 7,174
Turn off the whole house main breaker if you haven't the knowledge or skills to figure out the situation--
After you get this fixed---label your breaker box--
You seem to lack a basic understanding of household wiring---perhaps an electrician should be called---not everyone can or should do electrical work.
Old 12-16-2011, 01:46 PM   #11
buckybadger's Avatar
Rewards Points: 85
If it's an outside light make sure it didn't get chewed somewhere by rodents!
buckybadger is offline   Reply With Quote
Porch light unpowered by separate multi-way switch S_Jeff Electrical 11 12-13-2011 06:24 PM
Two part question on a porch light. J187 Electrical 2 12-07-2011 07:11 PM
New porch light. pwspivey Electrical 4 03-20-2011 01:20 PM
My new light fixture doesn't work! BBhomerepair Electrical 3 03-10-2011 09:05 AM
New porch light CB-PDX Electrical 4 03-09-2006 12:17 PM
