Old 02-09-2013, 08:16 PM   #1
Porch and closet
Hello all,
I am still working on my remodel and have reached the front porch. Adding the porch (10' x 16') also involved ripping off an old closet and adding it back correctly (10' x 3'). The back wall of the closet is one of the exterior walls and therefor backs up to the porch (total 10' x 19'). I am also adding a small laundry room with a stackable washer/dryer near there.
Goals:
1) I am turning that closet into a small sewing/hobby area and wanted to add a plug.
2) I need to have a plug on the porch.
Problems/Questions:
1) Should I, extend the bedroom (11' x 14') circuit (20 A), adding a plug for the closet and then out that shared wall to a GFCI plug.
2) Should I run a new 15 A GFCI circuit all together?
3) Is it ok to feed off the washer plug or is that required to be dedicated? The laundry room is close enough to all of this to be any easy tie.
4) Lastly, is there a required maximum/minimum distance that the GFCI porch outlet can be from the front door? I've been told there is, but I sure don't understand the logic and doing so will make this significantly harder.
Thoughts?
Thanks!
gmyers is offline   Reply With Quote
Old 02-09-2013, 10:54 PM   #2
Electrical Enthusiast
Porch and closet
I can't answer all your questions, but I can tell you that the Washing Machine circuit has to remain dedicated.
You could run a new 15 amp or 20 amp receptacle circuit, and place a couple of plugs in the hobby room, and install a GFCI plug on the front porch. Coming off the bedroom circuit may not be the best idea, due to AFCI requirements.
Some of your questions may depend upon the edition of the NEC that your area has adopted.
Kyle_in_rure is offline   Reply With Quote
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
gmyers (02-10-2013)
Old 02-10-2013, 12:21 AM   #3
Porch and closet
http://www.renovation-headquarters.c...-6-12-code.htm
No outlets in a closet, dedacated 20 amp. line to washer
Need to go back and add your location to your profile so someone on here would know what your local codes call for.
I would run 12-2 on a 20 amp breaker for the outlets so you could safely run a a space heater.
Old 02-10-2013, 08:06 AM   #4
Master Electrician
Porch and closet
Receptacles are allowed in closets by the NEC.
brric is offline   Reply With Quote
The Following 3 Users Say Thank You to brric For This Useful Post:
frenchelectrican (02-10-2013), jbfan (02-10-2013), oh'mike (02-10-2013)
Old 02-10-2013, 04:25 PM   #5
Porch and closet
... AFCI requirements...
Good point. Forgot about that one. Might tie the closet off the bedroom and then drop a new circuit for the porch.
Old 02-10-2013, 04:30 PM   #6
Porch and closet
washer: I wasn't sure, so thanks for clarifying.
closet: The layout of this closet allows it to be broken up into two smaller ones 2x (3' x 3') with the plug in the middle of it.
So, I'm hearing both "yay" and "nay". Which one is it?
Old 02-10-2013, 04:38 PM   #7
Porch and closet
Due to possible AFCI requirements,you could run the new closet plug off the bedroom circuit (is the bedroom the only thing on this circuit?), because technically bedrooms and other receptacle circuits will require AFCI breaker protection, depending on your local codes and whatever you are updating
The porch GFCI can have a new circuit.
Tags
closet, porch
Insulating enclosed porch countrygirl71 Insulation 2 09-17-2012 10:22 PM
What to do about a Damp Crawl Space under front porch? vpr80 Building & Construction 9 04-11-2012 09:32 PM
Cubby above a closet nlmedic Building & Construction 6 09-20-2011 11:35 AM
Bi-fold closet door question Breakthecycle2 Carpentry 4 04-28-2011 06:43 PM
closet or tile first ? littlerascal Remodeling 3 08-07-2010 01:19 PM
