-   -   Pop-up Kitchen Counter Receptacle (http://www.diychatroom.com/f18/pop-up-kitchen-counter-receptacle-66614/)
paredown 03-12-2010 09:25 AM
1 Attachment(s)
Well, this is an area where I need the help of the experts.
I've added a long extension to make a breakfast bar area--effectively a continuation of the kitchen counter. I have added a old work box at the end for a new GFI 20a double outlet (run #3 for the kitchen), but I need to add an outlet midpoint between the wall and the rest of the kitchen counter to meet the 4' rule (Thanks Will for the walk through!).
I physically could not add a new box above the counter when the wall was open because of solid framing behind--a combination of low window and doubled up 2x in the wall.
I found what seems to be the solution with this pop-up box from LEW--it is their PUP-CT-BK (black) or PUP-CT-SS for stainless. This is UL-approved to meet NEMA requirements.
http://www.lewelectric.com/cfm/comm_pufp.cfm (first two in list)
I also see mention on another thread for this box that some inspectors will not approve this as the first box in a GFI run.
Assume that I install the pop-up on the counter-top surface:
1.Can I wire from the existing counter end box attached to the underside of the counter?
Plan A would be to bring the BX out of the side or bottom of the new double box.
Run it behind end cabinet, physically attach to underside of counter top tight to the wall.
Would I use BX or? Can I use NM instead, or would this be considered exposed?
Just to confuse matters, for some reason, the install instructions I have read from APLUSSupply speak of using conduit: http://www.aplussupply.com/lew-floor-boxes/pufp.htm and see the link labeled "Instructions")
Then the new wall outlet becomes first in string--GFCI on first outlet and surface mounted box is last in chain, so I have avoided the problem of it being first in string.
Plan B would be to snake a new circuit up through the wall cavity, exiting a little to the left of where the box would sit. Then it is first in string...
If I adopt Plan B, would I need to use BX or could I use NM?
(reason for asking is that I have the most god-awful footing/wall cavity situation to get wires up from the crawl, that pulling a new BX may cause me to lose it completely and burn the place down.:furious:)
Cheers,
Dean
Scuba_Dave 03-12-2010 09:33 AM
Is this a peninsula ? Codes are different for a peninsula
They only require (1) receptacle to serve the peninsula
Do you have a pic of the area ?
http://i767.photobucket.com/albums/x.../21052-web.jpg
brric 03-12-2010 09:48 AM
I agree with Dave. IF you are intending to do this you might consider using the Lew PUFP-CT-SS or PUFP-CT-BK on a countertop. The round ones are intended for floor installation and will require a pvc floor box which is quite large.
There are other alternatives.
paredown 03-12-2010 10:39 AM
1 Attachment(s)
Thanks guys--I posted the right picture for the plug. I was a little distracted and grabbed the wrong one.
Here is a very rough drawing of the kitchen area, extracted from a larger drawing, so elements like the walls did not transfer over.
back of peninsula is bulked up to be even with the cabinet faces of area in nook; end cabinet on peninsula is not as wide as shown.
GFI 1 (as labeled) is circuit for short counter between fridge and oven; GFI-2 includes outlets on either side of cooktop and at end of peninsula.
These two feed from one subpanel.
GF-3 is the circuit in question--duplex outlet is in wall at RH end, & I've tried to show about where the counter top plug would be installed.
I didn't find other alternatives...
Thanks,
Dean
brric 03-12-2010 10:53 AM
Thanks,
Dean
I'm confused. Don't see GF-3. Are you talking about the 7'9" area at the lower right?
paredown 03-12-2010 11:01 AM
oops--yes that is the area. I think it didn't get picked up when I cut the drawing..
Edit: now posted a slightly better version
brric 03-12-2010 11:08 AM
So, That area is all counter space with no receptacles or is there a receptacle as drawn on the right?
HouseHelper 03-12-2010 11:09 AM
If I am reading your drawing right, I would say that new counter is outside of the kitchen area and that the "4' rule" no longer applies. You should be OK with just the receptacle at the end on the counter.
paredown 03-12-2010 11:23 AM
Should be clearer now--Counter top is continuous from end of peninsula.
Yes the receptacle already roughed in on the right. This the duplex box that I would tap into if I had to add the CT receptacle.
paredown 03-12-2010 11:25 AM
I wondered about that too--but the electrician who walked through thought I would need to meet the 4' rule. It is a separate alcove (it used to be the laundry area) but the flooring, countertops and cabinets all carry through from the kitchen proper.
Scuba_Dave 03-12-2010 11:32 AM
Are you alternating the circuits/outlets between areas ?
For instance where you have GFCI-1 you have 2 outlets
I would have one outlet on one circuit, 2nd outlet on another circuit
Same thing for GFCI-2 area
I would have another outlet on the short wall that leads to the 7' 9" area
paredown 03-12-2010 11:58 AM
Sorry that's not really a wall--solid stacked 2x behind since it's a bearing wall (not really there but Viso has a mind of its own about where it wants to put the anchor point for objects.) Window runs from end to end.
For better or worse, GF-1, GF-2 and GF-3 are each separate branch circuits. Because I'm working with old panels, I have limited breaker spots, and have already had to split them up between existing subpanels to make everything fit.
Edit: thought about this & I understand the idea of splitting the two circuits so that each counter has one plug from each--didn't think to do that initially.
The irony here is that the whole kitchen used to have one wall outlet that was on a shared circuit with the hood fan, a light circuit, the 120 stove circuit etc.:laughing:
