Pool Wiring Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-09-2012, 11:40 AM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by SeaDog1 View Post
Thats why I call this @%$! pool anotherhundred every time I turn around its another $100.....what wire do I need to use?....never mind I see your Quote!
You can use THWN, or XHHW... Pools can get tricky because of the amount of code requirements that go along with them... I would really refine your plan and post again so you don't miss anything...
Old 06-09-2012, 11:42 AM   #17
Licensed Pro
Is it because it's not in conduit or its not code?
Pool wiring requires an insulated ground. UF doesn't have that.
Old 06-09-2012, 11:43 AM   #18
E2 Electrician
Yet you can use it indoors... go figure.
Old 06-09-2012, 11:45 AM   #19
Actually now that I think about it the boxes will be mounted to the outside of a 12'X16' deck and will at least 12' for the side of the pool if that makes any difference?
SeaDog1 is offline   Reply With Quote
Old 06-09-2012, 11:49 AM   #20
The wire in question has a red,green,black and white that are each coated in a sheath is that not UF?
Old 06-09-2012, 11:57 AM   #21
E2 Electrician
I've never seen UF that contained an insulated grounding conductor. Take a picture and post it.
Old 06-09-2012, 11:58 AM   #22
E2 Electrician
http://www.mikeholt.com/files/PDF/Pooldownload.pdf
This is worth reading over, has some nice pictures to go along with it.
The Following User Says Thank You to stickboy1375 For This Useful Post:
k_buz (06-10-2012)
Old 06-09-2012, 12:17 PM   #23
Sorry for the poor quality if you can make it out it's black red green white?
Old 06-09-2012, 01:01 PM   #24
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
It will be so much esier to use conduit and pull individual THWN wires in the proper color and size. Even oversize it a little for future expansion. Much easier to pull the wire out and replace if something happens to it too. That uf stuff is a pita to pull out and replace.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
SeaDog1 (06-09-2012)
Old 06-09-2012, 01:28 PM   #25
I agree but, my dilemma is eating the $150 for wire I bought online that I can't return!
Old 06-09-2012, 01:38 PM   #26
rrolleston's Avatar
I can't tell for sure but it does not look like that wire has a separately insulated ground so unfourtunately it can't be used. Even if it did I am almost sure code does not allow that wire type.
Old 06-09-2012, 02:18 PM   #27
there are 4 wires each wrapped in a wire color plastic coating then all of those are wrapped in the gray outside plastic coating. I'm at work right now but my wife is going to take some pictures of the wire and send them to me and I will post them to give a better idea on what the wire is. and Thanks for your input on this!
Old 06-09-2012, 02:31 PM   #28
E2 Electrician
I don't see a green, I see a bare copper wire... I highly doubt it is insulated.
Old 06-09-2012, 02:33 PM   #29
E2 Electrician
As long as it has an insulated ground he's good to go, but it still has to be installed in conduit, which is really going to be a pain in the ass.... personally, i doubt an inspector will accept it because it will be such an oddity to find a UF with an insulated EGC...
Old 06-09-2012, 02:52 PM   #30
I called my local building inspector awhile back and was asking him about what I was doing and he pretty much told me that he usually doesn't come out for private residential putting up an above ground
pool that as long as I was doing it like code says it would be good? So with that I am mainly concerned with safety. So beside the wire issue which I'm pretty certain the the green wire is Insulated, but if
not I can get a solid insulated ground wire and install it. The only other concern is if I move the 20 amp gfci to the sub panel main feed can I use a regular 30 amp breaker in the main house panel to feed the
sub panel?
120v gas range wiring question Redfishjoe Electrical 5 05-11-2011 10:37 PM
Question on surface mounted wiring, plus ... NancyNGA Electrical 0 03-17-2011 02:11 PM
New Pool Installation Question Carla_Il Electrical 19 03-10-2010 09:33 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
Pool wiring jersey5.0 Electrical 4 10-07-2006 02:46 PM
