Pool Subpanel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 03:43 PM   #16
Electrician
Rewards Points: 150
Originally Posted by tone100 View Post
I'm starting to think I might just skip the whole prefab spa and do a built in. The cement ones =aren't comfortable but it looks like I don't have much choice.[/IMG]
I've seen a cement pool with a molded fiberglass spa. The spa was inset in the deck and had an overflow/waterfall into the pool. Same as a cement/cement pool/spa combo.
Tone100, the soffits are easy once you get the hang of it.
Glennsparky is offline   Reply With Quote
Old 03-26-2013, 04:06 PM   #17
Electrician
Rewards Points: 150
So it looks like I'm OK on the run. Does 100 amps look sufficient?
100A is huge. But it's your money. The largest, spa/2 pool pumps/lights scenario is about 75A.
Also are there any rules on distances for a above ground hot tub from a pool?
No. There is a bond wire, that is seperate from power wiring, that goes from pool equipment to spa equip. And an Equipotential Bonding Grid. But the pool contractor will sort those out. No biggie.
Old 03-26-2013, 04:16 PM   #18
Electrician
Rewards Points: 150
Tone100 please tell us your location. Go to the Quick Links pull down menu in the header of this page. Click Edit Your Details. Scroll down to location.
Old 03-26-2013, 04:24 PM   #19
I'm in Rockwall TX just outside of Dallas. The only reason I was thinkign 100 was just in case I needed moree power later. Can yo tel lme what the wire size would need to be for that long of a run in 100 amp vs 75 amp?
tone100 is offline   Reply With Quote
Old 03-26-2013, 05:28 PM   #20
Electrician
Rewards Points: 150
Based on 75*C or better rated terminations and wire, 240V for all pumps and heaters, 3% or less Voltage Drop.
#8 copper insulated green for the ground. Unless the spa instructions specify larger.
Neutral - White. If Cu, same size as the ground or #6 AL. Again, larger, if spa specs require.
90A double pole breaker. 75A load. Two hots:
#2 aluminum
#4 copper
100A DP brkr. 100A load. Two hots:
#1 AL
#3 Cu
Filling in our InGround Swimming Pool wnewman Landscaping & Lawn Care 17 04-22-2013 07:27 AM
Pool 100Amp Subpanel Lcarey Electrical 48 08-12-2012 12:33 AM
Pool subpanel questions Simbilis Electrical 3 04-23-2011 06:44 PM
Swimming Pool subpanel tedpoppke Electrical 3 08-24-2010 08:59 AM
Pool room subpanel rayt Electrical 3 10-06-2009 12:17 PM
