Old 07-02-2011, 08:11 PM   #1
Pool Subpanel
I bought my house last year and I was doing some work on my pool. I need to add a new new 220v device to the panel. I noticed that the neutral and the ground are both attached to the same bar. See attached picture. Is this an acceptable procedure?
thanks
Joe
jnassour is offline   Reply With Quote
Old 07-02-2011, 09:20 PM   #2
Electrical Contractor
kbsparky's Avatar
Pool Subpanel
Nope. That sub-panel is not wired properly.
It needs to have a separate grounding bar, and all the bare wires moved to it. Also, the box bonding screw needs to be removed.
Is there a ground wire contained in the main incoming feeder?
-KB
Old 07-02-2011, 09:28 PM   #3
kbsparky's Avatar
Pool Subpanel
I've added some items to your drawing:
-KB
Old 07-02-2011, 10:34 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
Pool Subpanel
KBsparky, did you notice the double tap? I would have to say that that is an old panel, or pulled out of a rehab job, and put there just recently. Also appears that that black in the middle of the bus bar is Aluminum.
gregzoll is online now   Reply With Quote
pool deck, carpenter help rollinastang Building & Construction 9 07-01-2011 07:21 AM
Pool subpanel questions Simbilis Electrical 3 04-23-2011 07:44 PM
Swimming Pool subpanel tedpoppke Electrical 3 08-24-2010 09:59 AM
Pool room subpanel rayt Electrical 3 10-06-2009 01:17 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 10:45 PM
