Pool And Salt Water Chlorinators - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 07:58 AM   #1
Pool and Salt water chlorinators
Hope I'm not far out of topic. The electrical circuit for for our pool is according to code and has a single, lock type receptacle on a post, 6' from the pool. I'm thinking of purchasing a salt water chlorine generator but I'm baffled trying to figure out how they are powered? How do they plug in? Any one have any experience with these?
Thank you.
whatrymes is offline   Reply With Quote
Old 08-02-2011, 08:33 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Thank you.
Start by reading the manufacturers installation instructions. Does it come with a cord and plug? It will probably need to be bonded. If it has a motor, it has to have a minimum #12 green insulated EGC.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-02-2011, 08:42 AM   #3
Rewards Points: 150
I would recommend against a salt water chlorinator. We make owners sign a waiver if they insist on putting in a salt pool because it is so corrosive to the components like grout and stone surrounds. Just a note of caution.
Broughton is offline   Reply With Quote
Old 08-02-2011, 09:05 AM   #4
It looks like there is a power center, cord and plug, that is 120V to convert the cell to 12V. I believe the code is one receptacle near the pool so I don't know were the new plug would go. Do I need to rewire the circuit and is a duplex receptacle now allowed??
Old 08-02-2011, 09:07 AM   #5
Thanks Broughton. I'm just weighing things out and that is certainly a consideration. This is an above ground pool, I have no grout or cement to worry about but there are aluminum rails etc.
Old 08-02-2011, 10:15 AM   #6
electures's Avatar
Is there a GFI receptacle no closer then 10' and no more then 20' from the pool? If so, it can be connected to that receptacle. How long is the cord?
Old 08-02-2011, 12:35 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Salt chlorine generators are typically hard wired into the pump circuit since they MUST go on and off with the pump. They draw next to nothing so they do not add to the load on the circuit.
Swimming Pool Pump & Salt Water Ctlr Wiring brianr Electrical 1 06-27-2011 06:02 AM
Salt water resistant decks stains mlopez Building & Construction 5 09-13-2010 10:14 AM
Please Help my pool is shocking the kids rnemt140 Electrical 105 07-21-2010 07:59 PM
white spots on gea verda tile around salt water pool mayo2965 Tiling, ceramics, marble 9 11-13-2009 05:37 AM
Wiring for swimming pool heater and salt system Scooby Electrical 1 06-08-2009 11:59 AM
