Pool Pump Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2008, 04:02 PM   #1
Rewards Points: 16
Pool Pump Wiring
Hi to everyone. I was hoping for some help in a situation I am having with a new pool. I will try to be as thorough as possible.
We purchased an intek pool about a month ago and discovered that the filter could not keep up with the pool use. It is an inexpensive filter that uses cartridges. I found a great deal on a Hayward S180T sand filter yesterday and purchased it. It has an Aquaflo 1.5 horse pump with it. I originally ran an underground conduit with 12/2 UF out to the pool onto a four by four riser with a weatherguard and GFCI protected outlet. My intek filter plugged right in and I was set to go. My problem is that the new pump (AO Smith LASAR) is only for 230 and apparently is a 2 speed pump. It has terminal connections for line and both high and low speed. I was told that I can run the existing common as the second leg and just install another breaker. I do moderate simple wiring but I was not sure if that was code or not. My second question is that if I did this, could I wire the motor with a plug and change out the 110 receptacle at the riser with a 220 receptacle? (I only ran the cable long enough to reach the riser and not where the actual pump location would be). Personnally I think I would only want the motor on the slow speed. It would provide more than adequate water turnover at a low speed and would eliminate the need for a switch to go from high to low speed. I really want to avoid buying another motor if I dont need to especially since this motor is suppose to be a quality motor. My main concern is safety for both myself and others using the pool. I do most projects myself and use utmost care when doing them so I am not ignorrant to the dangers of working with water and electricity. I just want to get the facts from people that know so I can decide if it is out of my league. Thanks in advance for any help that you may offer.
mpdive is offline   Reply With Quote
Old 06-15-2008, 04:23 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
This can be rewired for 220 but first off you can't use UF. The ground wire needs to be insulated. So, given that, your current set up isn't legal. We can give you more info as needed but this needs to be corrected first.
wirenut1110 is offline   Reply With Quote
Old 06-15-2008, 04:33 PM   #3
Electrician
Code Violation, cant use UF.
chris75 is offline   Reply With Quote
Old 06-15-2008, 04:41 PM   #4
Rewards Points: 510
Is there an echo here?
Old 06-15-2008, 05:30 PM   #5
Rewards Points: 6,652
Why go through all that hassle for a Sub $300 pool? For around $150, you could of gotten a 2500gpm filter pump if you really wanted to exchange the water more. http://www.brandsonsale.com/large-intex-pool-pumps.html
As for the original problem, you cannot run 220 on 12/2, and it would only stand up to 20 amps anyways. Do yourself a favor, and have an electrician come out, and wire the pump properly.
Old 06-15-2008, 05:39 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Guys, a storable pool does not follow the same rules as a permanent pool.
III. Storable Pools
680.30 General
Electrical installations at storable pools shall comply with the provisions of Part I and Part III of this article.
An insulated ground for the pump circuit is not mentioned in these two sections.
Be careful though. Local amendments are MANY for these new age pools.
In NY they consider these pools same as any other above ground pool and DO required the 48" barrier (fence) around the pool or yard.
Insurance companies hate them as well from what I hear.
Old 06-15-2008, 06:02 PM   #7
Electrician
III. Storable Pools
680.30 General
Some of those pools are deeper than 42", so that is considered a permanent pool.
Old 06-15-2008, 06:05 PM   #8
The most that a Storable pool goes in depth is 48", and unless it is Steel Wall construction, it is considered a "Storable" pool, not permanent.
Old 06-15-2008, 06:05 PM   #9
Electrician
Okay, since when cant you have 220 on a 12/2? And I've never seen a residential pool pump require a circuit bigger than 20 amps.
Old 06-15-2008, 06:07 PM   #10
Because of the length from the Subpanel, or Main Panel, you will no less then 10/2 or 10/3 to a Pool Circuit. As for 220, I personally would not put that much on anything less then 10/2 in my area, due to the particulars.
Old 06-15-2008, 06:09 PM   #11
Electrician
I only have my 2002 nec in front of me, but 680.2 Definitions, Pools capable of holding water in a depth greater than 42 in. is a Permanently Installed Pool. ? Yes/No?
Old 06-15-2008, 06:09 PM   #12
Electrician
What are you talking about?
Old 06-15-2008, 06:12 PM   #13
The Intex pools are considered Storable, and are not considered Permenant. As for the 2nd, our area will not allow 12/2 to carry 220vac, and follows the 2008 NEC.
Old 06-15-2008, 06:19 PM   #14
Electrician
What area are you talking about, and I hope you have a state amendment for this ridiculous rule.
Old 06-15-2008, 07:33 PM   #15
Rewards Points: 510
Sorry, didn't know this pool was a storable.
Outdoor wiring to pool pump svanvolk Electrical 4 06-10-2008 07:15 AM
Wiring 240v pump to generator - URGENT Benchr Electrical 4 12-19-2006 06:50 PM
Pool wiring jersey5.0 Electrical 4 10-07-2006 02:46 PM
Pool Wiring phinfan1266 Electrical 4 06-27-2006 03:31 PM
GFI Breaker & pool pump mitchman333 Electrical 7 05-08-2006 06:32 PM
