Pool Pump Outlet And Bonding - Electrical - DIY Chatroom Home Improvement Forum
Old 08-05-2012, 06:40 AM   #1
Pool pump outlet and bonding
Hello everyone I'm new to diy. I was wondering if anyone is familiar with oklahomas code for wiring pool pumps and having pool bonded?
bhill0214 is offline   Reply With Quote
Old 08-05-2012, 08:29 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
I don't know about OK specifically, but what is your question?
Old 08-05-2012, 08:35 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There are umpteen zillion codes when it comes to pool installations. You are going to have to check with your community's building/inspection department before you make any plans.
The Following User Says Thank You to k_buz For This Useful Post:
Speedy Petey (08-05-2012)
Old 08-05-2012, 09:44 AM   #4
My pump and filter is set 3' beside the pool. I was needing to know if my outlet for the pump can be that close and can it be a gfci plug or does it have to be a twist lock plug? And do I need a ground rod next to the pool? How do I bond it all to?
Old 08-05-2012, 09:48 AM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I see this with every above ground pool I wire, they install the filter and motor way to close to the pool....then they end up coming back to move the equipment to where I installed the receptacle.
Old 08-05-2012, 09:50 AM   #6
E2 Electrician
680.22 Area Lighting, Receptacles, and Equipment.
(A) Receptacles.
(1) Circulation and Sanitation System, Location. Receptacles that provide power for water-pump motors or for other loads directly related to the circulation and sanitation system shall be located at least 3.0 m (10 ft) from the inside walls of the pool, or not less than 1.83 m (6 ft) from the inside walls of the pool if they meet all of the following conditions:
(1) Consist of single receptacles
(2) Employ a locking configuration
(3) Are of the grounding type
(4) Have GFCI protection
Also, read this, as it pertains to your installation.
(5) Cord-and-Plug Connections. Pool-associated motors shall be permitted to employ cord-and-plug connections. The flexible cord shall not exceed 900 mm (3 ft) in length. The flexible cord shall include a copper equipment grounding conductor sized in accordance with 250.122 but not smaller than 12 AWG. The cord shall terminate in a grounding-type attach- ment plug.
Old 08-05-2012, 09:54 AM   #7
E2 Electrician
What is the water depth of the pool? If under 42" then no bonding is required, if over 42" then bonding is required, and this does NOT involve a ground rod.
Old 08-05-2012, 10:07 AM   #8
(A) Receptacles.
Ok not to sound stupid but I don't live within city limits so does that same code still apply?
Old 08-05-2012, 10:09 AM   #9
E2 Electrician
The NEC is a national code, but if I were you, I would make some phone calls on what is required....
The Following User Says Thank You to stickboy1375 For This Useful Post:
bhill0214 (08-05-2012)
Old 08-05-2012, 10:12 AM   #10
The pool is 54". So how do I go about making sure it is all bonded?
Old 08-05-2012, 10:17 AM   #11
Ok. Thanks for the help
Old 08-05-2012, 10:17 AM   #12
So you are basically asking for all the codes and wiring related to a permanent above ground pool.
My suggestion is to either get a copy of the NEC and read ALL of Art.680 I & II, and a few good books on basic wiring, or call an electrician to come over and do the job properly.
Old 08-05-2012, 10:19 AM   #13
E2 Electrician
I have to agree, I cant reprint everything verbatim, too easy to miss something as in every scenario is different, this would turn into a 500 page thread, do some reading, then ask for clarifications on your questions.
I'll even get you started, here is a great link to article 680....
http://www.erbinspections.com/Forms%...tallations.pdf
Above ground pool circuit Juance Electrical 31 07-28-2012 01:01 PM
Pool bonding HELP!!!!!!!!! bgyako Electrical 34 08-25-2011 10:28 AM
Wiring for swimming pool jomay Electrical 95 08-03-2011 11:48 PM
bonding and grounding of pool pump/motor gpike19 Electrical 2 07-22-2011 01:18 PM
Pool wiring jersey5.0 Electrical 4 10-07-2006 02:46 PM
