Pool Pump Is Out - Electrical - DIY Chatroom Home Improvement Forum
Old 07-03-2012, 01:57 PM   #1
Pool pump is out
Power to pump from circuit breaker 3 wires 2 black one white,each black wire reads 120 V when checked to ground, when I check the 2 black wires don't get any volts reading.Pump runs when tested directly to 120V outlet.
Pump suppose to be 1Phase 240V.
Need help to figure out what is the problem.
vsrleon is offline   Reply With Quote
Old 07-03-2012, 02:09 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,864
Is there a timer or switch? What is the white wire for? Is there something else on this circuit?
mpoulton is offline   Reply With Quote
Old 07-03-2012, 02:13 PM   #3
Rewards Points: 3,256
Is this a new install or was it previously working? Could you have both blacks on the same phase?
zappa is offline   Reply With Quote
Old 07-03-2012, 02:29 PM   #4
Pool pump out
Pump was installed 3 years ago just quite running 2 weeks ago
Old 07-03-2012, 02:31 PM   #5
There is a timer white is ground not been use
Old 07-03-2012, 03:18 PM   #6
This doesn't sound like it was wired by someone qualified. White should never be used as ground. Regardless, you should start by measuring voltage between the two hot wires (black) at various points along the circuit: at the breaker, at the input to the timer, at the output of the timer, and at the motor. You should read 240V. A reading of 120V indicates that there is a break in one of the hot wires upstream of that location. So if you measure 240V at the input tot he timer and 120V at the output, then you know one pole of the timer switch is bad.
Swimming Pool Pump & Salt Water Ctlr Wiring brianr Electrical 1 06-27-2011 07:02 AM
What size wire for above ground swimming pool pump jshep105 Electrical 12 05-28-2011 07:43 AM
New pool pump trips breaker?! New home owner needs advice. KenR7A Electrical 22 01-05-2011 10:42 AM
Pool Heat pump ryts4 Electrical 3 04-02-2010 06:53 AM
