Pool Light Troubleshooting - Electrical - DIY Chatroom Home Improvement Forum
Old 07-21-2012, 02:50 PM   #1
Just a DIY guy
Question
pool light troubleshooting
I have an in-ground pool with two lights, one for the pool and the other for the spa. At some point they stopped working. THere is a subpanel by my pool equipment, marked "pool lights." when I switch the breaker, my non-contact voltage tester reads hot when the breaker is on, and dead when the breaker is tripped, so it seems I have power there. (I did not pull the panel off yet, just held the tester up against the breaker)
I pulled the cover off of the light switches, and there is no power there.
Unfortunately, there is a large expanse of concrete patio between the switches and the subpanel (and even the main panel), and all the wires run underneath it.
I'm kind of lost on how to troubleshoot this, are there any tricks to troubleshooting this type of problem?
FYI - I have a non-contact voltage tester and a cheapo digital multimeter, and have done some simple wiring projects like running circuits for new receptacles.
M3 Pete is offline   Reply With Quote
Old 07-21-2012, 02:58 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
If the pool lights are run directly back to the sub panel, I would eliminate the switches out of the picture by wiring the lights directly to the breakers and see if they work. You have to start somewhere, also, where is the GFCI protection located? Is that tripped? Take some pictures of your setup, will help big time on troubleshooting this for you.
Ceiling light install gone bad--need help troubleshooting Jsifers Electrical 7 08-11-2011 08:18 PM
Basic light wiring question speedster1 Electrical 3 11-29-2010 06:48 PM
Pool Pump & Light Wiring Nod Electrical 28 07-15-2008 04:49 PM
Pool Table Light in Drop Ceiling JJdeadhead Electrical 5 04-18-2007 08:01 AM
Swimming Pool Light Broc Electrical 1 08-15-2006 02:23 PM
