Pool Light Problem - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-26-2008, 11:14 AM   #31
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Don't know how that it explains the light working intermittently tho! I'd have thought that once a fuse has blown the light could not have worked!?
Me too but stranger things could have been going on. Yes in Europe they use fuses at the switches usually 5 amp ones that snap into small fuse blocks on the switch box. I actually forgot this (don't work much on your systems....) or would have suggested you check. Thanks for getting back and telling us what the problem was...it will help in the future.
As a side note you use 230 volts over there and we use 120 volts over here. The low voltage stuff like your lights are the same but that 230 volts will shake the morning dew off you... if you get shocked by it. So be careful around that stuff.
If I'm ever in your neck of the woods I'll just ask "where are the transplanted brits living"..... I'll bet they will know.....
Take Care SharonW
Old 07-26-2008, 03:42 PM   #32
" Euro " electrician
frenchelectrican's Avatar
Stubbie .,, I know I am pretty late to join in here but senice the OP mention fuse in low voltage transfomer and Yes it is common in European verison and also it will be on the RCD {GFCI} breaker as well.
Merci,Marc
Replace pool light DONRILEY Electrical 5 07-20-2008 05:51 PM
Pool Pump & Light Wiring Nod Electrical 28 07-15-2008 05:49 PM
2 switches , one light problem pepperthecat Electrical 2 07-08-2008 04:57 PM
Pool light Junction Box Al the Diy guy Electrical 9 02-11-2008 09:28 PM
Swimming Pool Light Broc Electrical 1 08-15-2006 03:23 PM
