-   -   pool light problem (http://www.diychatroom.com/f18/pool-light-problem-23900/)
SharonW 07-19-2008 06:54 AM
pool light problem
Hi hope someone can help!
We have 2 pool lights, both operated from the same switch in the house. One light works perfectly, the other does not work at all! We have changed the bulb and that still does not solve the problem. We are out of ideas! :(
JohnJ0906 07-19-2008 07:03 AM
Lights in the pool, or at the pool?
Can you give a little more detail please.
SharonW 07-19-2008 07:07 AM
Thanks for reply John,
Should have more clearer!! 2 lights IN the pool!
chris75 07-19-2008 07:10 AM
Did you install the correct lamp? I did a relamp job once and the new lamp was just slightly different than the original and would never make contact,
Also, open up the pool light deck box and check that you do in fact have power going to the light.
SharonW 07-19-2008 07:15 AM
Yes defo correct lamp! Forgot to mention, when we changed the 'lamp' it worked! So 2 nights looked lovely! Then it went out and would not come back on! Then a few weeks later just on the off chance i flipped the indoors switch again (waiting for a miracle!) and voila! it worked! Next day out again and permanently ever since!
chris75 07-19-2008 07:18 AM
What kind of lamp is in the pool? Quartz Halogen? Did you touch the lamp with your bare hands?
SharonW 07-19-2008 07:23 AM
Yes halogen, and i would say it is VERY likely that it was touched with bare hands! Does this make a difference?
chris75 07-19-2008 07:25 AM
Yeah, usually causes shortened lamp life, but your scenario seems too short.
It very well could be just a bad lamp, did you try replacing it a 2nd time? also, I would swap lamps around with the other pool light to verify if the problem is the lamp, or the light.
SharonW 07-19-2008 07:33 AM
Actually this is the 3rd lamp! first when we bought the house, we got both changed. One light is still working perfect after 14 months. The lamp in question stopped working (albeit it came on a couple of times!) after 4 months. Not sure if it is a coinsidence but it stopped working after ew had an horrendous hail storm (size of golf balls!) Have not tried changing lamp over, don't know if I dare!
Thanks a lot for your help, btw!
Keniki 07-20-2008 10:33 AM
Try switching the two bulbs and see if you have the same problem or if it reverses. I have seen bulbs with a broken filament work sometimes, depending on the position of the bulb. While the bulbs are out of the sockets, you could try them in a lamp if they are medium base, and see if they both work then.
SharonW 07-21-2008 03:17 AM
Thanksfor reply -
But the bulb is in a sealed unit - when I said in an earlier post that the bulb had been touched I mean't the glass surrounding it!
220/221 07-21-2008 06:42 PM
You will likely have TWO seperate brass pool light junction boxes outside, above ground in the landscaped area close to the lights.
Carefully, look for a loose connection there. If you are lucky, your problem will be there.
More likely, the halogen pool lights get very hot inside and tend to burn up at the lamp socket/pins. You may have to replace the fixture.
SharonW 07-22-2008 03:18 AM
Thanks,
Have checked the junction boxes and no loose wires!
Stubbie 07-22-2008 04:10 AM
Are they low voltage lights...12volts? If so I'd locate and check the transformer connections. Could also be a bad transformer.
Usually sealed lights are found with above ground pools so is that what you have?
SharonW 07-22-2008 04:14 AM
Thanks Stubbie, and no we have an in the ground pool.
