Pool Electrical...very Confused/frustrated - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2010, 03:04 PM   #1
Rewards Points: 150
Pool electrical...very confused/frustrated
First off, I am going to call a pool/electrical guy...I realize I am in over my head.
I just bought (online) a Hayward PowerFLo LX 1.5HP pump for my 30,000 above ground pool. It did not come with a on/off switch. I found out today (after the pump arrived) that I have to order that separately. This pump came with a traditional three prong cord. I thought that pool equipment had to have a twist lock cord????? I don't know if I should return the pump and get one with a twist lock? Is three prong ok? I would have to convert my outlet from twist lock to three prong.
joemontana16 is offline   Reply With Quote
Old 03-06-2010, 03:31 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
It needs to be twist-lock if it's located within 10' of the inside wall of the pool. if it's more than 10' then a regular plug is ok. Of course GFI protected.
wirenut1110 is offline   Reply With Quote
Old 03-06-2010, 03:36 PM   #3
Around here a pool pump is also required to be on a timer
I have mine on a timer & I have a switch near it to shut it off
My pump is also connected to the bonding (?) grid of the pool
Old 03-06-2010, 03:38 PM   #4
Rewards Points: 510
Is this a new pool or are you replacing the pump? If it is a new pool then yes, I would get someone that knows about it.
Old 03-06-2010, 03:53 PM   #5
Rewards Points: 150
Old pool - new owner. I am replacing the same model pump..this one just arrived with a different cord, must be cheaper. How easy would it be to swap the cords (twist lock from old pump to new pump)?
Old 03-06-2010, 04:04 PM   #6
Most twist locks I have seen have screws holding them together
So fairly easy to open them up
Just make note of which wires go where
Old 03-06-2010, 04:05 PM   #7
Rewards Points: 510
Is the twist-lock a factory installed plug? It looks like your pump is single voltage (120V)? If the plug is removable, just change that.
Pool parts...what is this for? tripflex Plumbing 5 02-17-2012 06:32 AM
First thing to do to pool? tripflex General DIY Discussions 21 09-29-2009 11:55 AM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
voltage potential around in-ground pool logi98 Electrical 20 07-05-2009 08:08 PM
Above Ground Pool+Deck Electrical Install (Ontario, Canada) hecubus Electrical 5 08-02-2008 01:42 PM
