Pool Electrical Code Question - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 03:17 PM   #1
Our local code requires GFCI protection to be between 10 and 20' from edge of pool. Pump twist lock receptacle must be between 5 and 10'. My breaker is about 50' from the pool, so GFCI breaker will not by itself suffice. Does this mean that I have to come up twice from my underground PVC run - 1st for GFCI outlet, 2nd for twist lock and safety switch? Am I understanding this correctly?
I will have an electrician confirm my work (updating my fuse box), but I want to ensure I do things right the 1st time.
WES_70 is offline   Reply With Quote
Old 07-07-2012, 03:21 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
The pump receptacle MAY be 5-10 feet from the pool. It doesn't have to be. It can be further.
The distance does not matter. A GFI breaker, even 50' away, is all that is required to protect the pump circuit.
Electrical Code in Chicago!?! moose186 Electrical 37 12-28-2014 12:27 PM
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 10:19 AM
Electrical run to new pool house AlwayzSomethin Electrical 11 04-26-2012 01:47 PM
Question about electrical wires outside of new house.. mhp8982 Electrical 8 10-05-2010 07:26 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
