Pool "current" - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 09-20-2011, 08:50 AM   #61
Originally Posted by uconduit View Post
Simple.... You had voltage to ground, your pool light was grounded. Glad I could help!
Not sure what you are saying here. From reading this chain, seems there is stray voltage in the ground or my nuetral is higher then ground. The light ties the water to nuetral threfore providing a current path from the deck to the water. I have not seen a solution posted yet to fix this. One thing that is confusing to me is that the ladder is a direct conenction from the ground/deck to the water. Why doesn't this bleed the stray voltage? If my nuetral is higher then the earth, should this also not cause a current flow down the ladder and to the light which in turn would trip the GFCI? Perhaps the current is not high enough?
muffin99 is offline   Reply With Quote
cement pool deck... acrylic, epoxy or stain? vickipalma Painting 4 09-17-2009 02:09 PM
Swimming Pool Converted To Fish Pond ghall79 General DIY Discussions 6 05-23-2008 12:11 PM
Moles unde pool liner...causing "craters" abacuslearns Landscaping & Lawn Care 1 10-27-2007 08:37 AM
Pool wiring jersey5.0 Electrical 4 10-07-2006 02:46 PM
Pool Wiring phinfan1266 Electrical 4 06-27-2006 03:31 PM
