Pool Bonding Question.? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-27-2009, 11:53 PM   #1
pool bonding question.?
I understand that i have to run #6 bare copper around the pool hitting all metal parts but my pool is a semi-inground. Every four feet or so there is a metal support going down the side of the pool. Do i need to put a bonding lug on every single one? There is probably 30+ of them. The metal frame of the pool is all connected to each other so i dont understand why i would have to hit every single one to be "code compliant"
Philip
pjwinstalls is offline   Reply With Quote
Old 06-28-2009, 12:17 AM   #2
Electrical Contractor
kbsparky's Avatar
The minimum bonding conductor size is #8 bare solid copper. And, yes, you have to ensure all metal parts including rebars, coping, ladder and handrail cups, etc. are electrically bonded and connected.
Are you dealing with an above-ground pool that is partially buried?
-KB
Old 06-28-2009, 02:02 AM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
If the pool walls are metal and are continuous from support pole to support pole you do not have to bond everyone. Some jurisdictions only require that you bond to one of them & some want the metal wall bonded in 4 places etc...
It can depend on local requirements if there are none then I would bond to two of them and call it a day. Here is an example of one jurisdictions requirements.....
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 06-28-2009, 02:02 AM   #4
Yes, it is a above ground pool that is about 12" above the surface, the rest underneath with a deep end. But my question is do i have to hit all 30-40 metal supports even though they are all connected by a metal top rail that goes around the entire pool??
I was going to use #6....will #8 meet code because that would be easier to work with and less expensive...?
Thanks again!
Old 06-28-2009, 02:04 AM   #5
thanks Stubbie....you answered my questions the same time i posted them!! Hopefully i can find that info about how many supports to bond to in the NYS code book but i doubt it.
I have 4 ladder cups bolted to my wood deck, do i have to bond to those as well?
Old 06-28-2009, 02:32 AM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Probably a good idea and required if part of the permanent structure around the pool, some jurisdictions require this only if 5 feet or closer from the waters edge.
Stubbie
Bonding for Pool Equipment Elecman Electrical 9 03-23-2010 04:09 AM
Pool Motor Question...Please Help! gmcf2004 Electrical 13 06-01-2009 08:34 PM
mortar liquid bonding agent question drewhart Building & Construction 5 11-06-2008 08:45 PM
Inground Vinyl Pool Question intofire Landscaping & Lawn Care 0 09-11-2008 11:34 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
