Pool Bonding HELP!!!!!!!!! - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 02:54 PM   #31
Master Electrician
Rewards Points: 3,958
I think you've already been told the ground rod is not needed.
Grounds and neutrals should be isolated from each other in the shed panel.
brric is offline   Reply With Quote
Old 08-23-2011, 03:01 PM   #32
That makes sense now..
Sounds like because ground and neutrals on the same bar in the sub panel is causing the difference when adding ground rod.
So to properly wire this. I need to separate the ground wires from neutrals and connect the bonding wire back to motor.
Thanks for all your help./.....
bgyako is offline   Reply With Quote
Old 08-23-2011, 03:45 PM   #33
Code05's Avatar
Rewards Points: 1,104
This whole project has a permit and inspection?
Code05 is offline   Reply With Quote
Old 08-23-2011, 03:56 PM   #34
Sure.. Like all above ground pools do.
Anyway, having electrician come to double check everything tomorrow.
Old 08-25-2011, 09:28 AM   #35
Resolution:
Hey brric thanks for all your help you hit it on the head.
The electrician came by last night, everything I wired is correct.
The existing sub panel had was the problem.
Once he separated the neutrals from the ground, everything worked perfect.
Just needed an isolated ground bar.
Thanks again to everyone.
Bonding Pool Equipment - Conflicting Advice rickster18 Electrical 6 08-18-2011 05:21 PM
pool bonding philmymtpkts Electrical 11 08-03-2011 10:43 PM
bonding and grounding of pool pump/motor gpike19 Electrical 2 07-22-2011 12:18 PM
Tips on how I can get this electrical job done for a hot tub in backyard. the punisher Electrical 34 08-24-2010 06:08 PM
Another Pool Bonding Question RustyRealtor Electrical 4 08-05-2009 01:15 PM
