Pool Bonding HELP!!!!!!!!! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 02:31 PM   #16
Originally Posted by bob22 View Post
How is the electricity delivered from the shed to your outlet that the pump plugs into? UF, NM, THWN, etc, underground and/or in conduit?
From sub panel in shed via 12/2 romex to a box which holds a GFCI outlet.
bgyako is offline   Reply With Quote
Old 08-23-2011, 02:41 PM   #17
Code05's Avatar
Rewards Points: 1,104
Ain't legal......
680.21 Motors.
(A) Wiring Methods. The wiring to a pool motor shall
comply with (A)(1) unless modified for specific circumstances
by (A)(2), (A)(3), (A)(4), or (A)(5).
(1) General. The branch circuits for pool-associated motors
shall be installed in rigid metal conduit, intermediate
metal conduit, rigid polyvinyl chloride conduit, reinforced
thermosetting resin conduit, or Type MC cable listed for the
location. Other wiring methods and materials shall be permitted
in specific locations or applications as covered in
this section. Any wiring method employed shall contain an
insulated copper equipment grounding conductor sized in
accordance with 250.122 but not smaller than 12 AWG.
Code05 is offline   Reply With Quote
Old 08-23-2011, 02:44 PM   #18
Rewards Points: 1,568
It could be legal if the outlet serving the pump is mounted to the shed thereby not needing conduit etc... since the cable run would be inside the shed, through the wall, and right into the JB, correct? Of course, this may not be what is there...
bob22 is online now   Reply With Quote
Old 08-23-2011, 02:55 PM   #19
That's exactly how it is wired..
People are looking for flaws instead of assisting in correcting my problem.
Old 08-23-2011, 02:57 PM   #20
No, people are trying to visualize what is happening when they can't see it and trying their best to make sure the installation is safe so you or your family don't get electrocuted. No one responding knows if you know what you are doing and how to do it right so they err on the side of being overly cautious. That makes sense to you doesn't it?
The Following User Says Thank You to bob22 For This Useful Post:
Jim Port (08-23-2011)
Old 08-23-2011, 03:04 PM   #21
Master Electrician
Rewards Points: 3,750
NEC 2008 680.21(A)(4) allows NM cable for the interior portions of this wirinng for dwelling units and structures associated with dwelling units.
brric is offline   Reply With Quote
Old 08-23-2011, 03:07 PM   #22
I guess but throwing codes at me is not helping ..
I thought I had it wired correctly, what's messing me up is the bonding.
and that's causing breaker to trip.
Break down.
This set up works with no issues.
Main panel has 30 amp GFCI 2pole breaker.
10 AWG cable goes to sub panel in SHED>
From sub panel, I have 12/2 romex going to Junction box inside shed.
Junction box has GFCI outlet that the motor plugs into.
Issue:
I bonded all the parts of the pool to a ground rod.
then bonded motor case to same ground rod.
Breaker started to trip. I temporarily removed bond from motor until I figure this out.
It sounds as if I did not need the ground rod>>>>
Old 08-23-2011, 03:34 PM   #23
Master Electrician
Break down.
Issue:
Try removing the connection to the ground rod and see what happens.
Old 08-23-2011, 03:36 PM   #24
Master Electrician
How many conductors are going to the sub panel in the shed?
Old 08-23-2011, 03:38 PM   #25
4 - black, red, white, and ground.
Old 08-23-2011, 03:39 PM   #26
If I remove the bonding copper wire from motor case it is working properly.
I want to make sure the pool is properly bonded and was advise need ground rod.
Old 08-23-2011, 03:40 PM   #27
Master Electrician
Are the grounds and neutral isolated ?
Old 08-23-2011, 03:45 PM   #28
Master Electrician
Is the motor dual voltage and is set up for 120 volts?
Old 08-23-2011, 03:48 PM   #29
Not in the sub panel, no.....
Old 08-23-2011, 03:49 PM   #30
I do not think so. I think it is 120 only.
It does have 2 speeds, low/high. Controlled by toggle switch built into motor.
Bonding Pool Equipment - Conflicting Advice rickster18 Electrical 6 08-18-2011 06:21 PM
pool bonding philmymtpkts Electrical 11 08-03-2011 11:43 PM
bonding and grounding of pool pump/motor gpike19 Electrical 2 07-22-2011 01:18 PM
Tips on how I can get this electrical job done for a hot tub in backyard. the punisher Electrical 34 08-24-2010 07:08 PM
Another Pool Bonding Question RustyRealtor Electrical 4 08-05-2009 02:15 PM
