Pool Bonding - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 10:20 PM   #1
pool bonding
Hi i have a semi in ground pool When bonding my pool, I ran #8awg bare copper wire from the pool to the salt water generator then to the pump. my question is do I tie it in to the ground wire from the 12awg pool pump receptacle circuit or does it stop at the pump housing? Also I have 12volt led pool light in the pools return. Can I run that off the same 20 amp feed that I am using for the pump or does it have to be a dedicated circuit, to pass inspection . Thanks
philmymtpkts is offline   Reply With Quote
Old 08-02-2011, 10:32 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Bonding wire stops at filter motor. Run a dedicated circuit for the filter motor. Convenience receptacle has to be GFI and can be done in UF. LED light can plug onto convenience receptacle.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
NJMarine (08-03-2011)
Old 08-03-2011, 09:55 AM   #3
Thanks for your fast reply? Now I have another question a freind of mine recently had his pool inspected, his was tied onto the ground and passed! which way is safer?I certainly don't want to get lit-up and I would like to tell the inspector why I stopped it at the motors housing if asked, but I would want to know why it is safer so I can also let my friend know. I really dont care if an inspector passes me i want it to be safe thats all. Thanks.
Old 08-03-2011, 10:18 AM   #4
Old 08-03-2011, 11:56 AM   #5
electures's Avatar
Motor is grounded through branchcircuit conductors. Pool is bonded to motor with #8 bare. There is no need for another connection. The inspector better know the difference.
Old 08-03-2011, 02:25 PM   #6
So is my freinds pool bonded correctly/ safe ?did the electrician just add an extra connection for saftey ..Thanks
Old 08-03-2011, 03:40 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
No, he added it because he didn't know any better. Just like people that sink ground rods for pools.
The Following User Says Thank You to Speedy Petey For This Useful Post:
philmymtpkts (08-03-2011)
Old 08-03-2011, 04:46 PM   #8
electures's Avatar
That, and he doesn't understand the difference between grounding and bonding.
Old 08-03-2011, 08:59 PM   #9
The scary thing is the inspector passed it!!
Old 08-03-2011, 09:39 PM   #10
electures's Avatar
The NEC does not prohibit it.
Old 08-03-2011, 10:08 PM   #11
So since he is tied into the ground wire, there would be a better chance of electric current flow to the pool ? Can you expain how this would or could happen ? You know its crazy but you have a professional do a job for you and then you have it inspected and it passes you would think it is safe!!
Old 08-03-2011, 10:43 PM   #12
electures's Avatar
It's not really a big deal because the bond wire is connected to the motor which is grounded by the #12 EGC in the branch circuit. So the entire pool in grounded indirectly anyway. My bigger concern ( Petey stated this earlier) is when a ground rod is driven at the pool and connected to the bonding wire.
There is another post containing this here.
NJMarine (08-04-2011)
bonding and grounding of pool pump/motor gpike19 Electrical 2 07-22-2011 12:18 PM
Grounding a swimming pool bonding grid Simbilis Electrical 8 05-25-2011 11:46 AM
Tips on how I can get this electrical job done for a hot tub in backyard. the punisher Electrical 34 08-24-2010 06:08 PM
Another Pool Bonding Question RustyRealtor Electrical 4 08-05-2009 01:15 PM
pool bonding question.? pjwinstalls Electrical 5 06-28-2009 01:32 AM
