Pool 100Amp Subpanel - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-11-2012, 12:58 AM   #31
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by stickboy1375
Why is this so hard for electricians to comprehend? They choose opinion over code... As if the way they wire is supposedly better? For who though, the customers wallet or their own ego?
Because they would have to step outside of their comfort zone and actually read the NEC. It is easier to follow then to lead.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-11-2012, 12:59 AM   #32
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by stickboy1375 View Post
But where does the " is it really better logic" come into play? It is a legit install, and perfectly safe.
As long it is legit set up and done properly it is comply safe.
But where the " it is really better logic " really there is none as long you use the common sense that about it.
Merci,
Marc
Old 08-11-2012, 01:00 AM   #33
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Merci,
Marc
Im perfectly confident with a EGC providing all the safety one needs.
Old 08-11-2012, 01:02 AM   #34
That part I do agree with you.,
Just keep in your mind with the proper EGC set up it will work very well in case the RCD do fail ( belive me I have see some RCD fail and kick out the OCPD on that )
Merci,
Marc
Old 08-11-2012, 01:09 AM   #35
Master Electrician
I disagree with that logic, you have a hard wired pump with a EGC, How is a GFCI better than THAT?
you can disagree all you want, but it's code here so that's how it gets done
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-11-2012, 01:10 AM   #36
E2 Electrician
And that's acceptable... but I would not find it a better job, just another mandate and expense. so thumbs down for me....
Old 08-11-2012, 09:39 AM   #37
electures's Avatar
code is bare minimum safety wise, i don't see an issue with wanting better than the bare minimum. I give the option to everyone i do work for that they can do it one way and have it cost less or they can spend a little more and have something better than the minimum.
Our code states that all pool equipment has to be wired with gfci protection no matter the motor size, It also has to be permanently wired, so no plugin motors.
What code is that?
Old 08-11-2012, 09:40 AM   #38
E2 Electrician
Originally Posted by electures View Post
what code is that?
cec....
The Following User Says Thank You to stickboy1375 For This Useful Post:
electures (08-11-2012)
Old 08-11-2012, 09:42 AM   #39
electures's Avatar
cec....
California or Canada?
Old 08-11-2012, 09:43 AM   #40
E2 Electrician
The latter, Canada. Im slowly learning the CEC, interesting in some aspects.
Old 08-11-2012, 11:24 AM   #41
Rewards Points: 322
Is an an insulated ground required to the pool house?
tribe_fan is online now   Reply With Quote
Old 08-11-2012, 11:29 AM   #42
E2 Electrician
Yep... 680.25 (B) There is an exception though....if it is already existing.
Old 08-11-2012, 02:18 PM   #43
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Sorry, but I do not like this comment.
I really hope you don't think this applies to most of us here.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
jbfan (08-11-2012)
Old 08-11-2012, 02:53 PM   #44
electures's Avatar
No, not to most but there are a few. Unfortunately, there are a lot of electricians who learn by failing instead of taking a class or participate in a forum such as ElectricianTalk.
As soon as something out of the norm comes along, it's easier to say it is wrong then to prove it is wrong.
If anybody thinks I am wrong, prove me wrong. I don't want to hear about intent or cost. Time and time again I hear contractors pissing and moaning about how the EI wants this or that and they think it is wrong. I am actually pointing out away for a contractor to save a few bucks without violating the NEC.
A lot of EI's here in NJ didn't grasp this either when I introduced it, but the code specialists in the DCA agree with me along with my local IAEI chapter.
Old 08-11-2012, 02:58 PM   #45
Well, I am not saying you are wrong, but I am saying I disagree.
I am not one of these guys who over builds every job just to say how much better I am than the other guy, or to just cover my ass because I don't know the code.
That said, I do feel there are areas though were I feel code minimum is not good enough.
Pool subpanel Roskoe General DIY Discussions 0 12-17-2011 09:25 AM
Pool subpanel questions Simbilis Electrical 3 04-23-2011 07:44 PM
Swimming Pool subpanel tedpoppke Electrical 3 08-24-2010 09:59 AM
Adding 100amp Subpanel for basement trajendra_babu Electrical 22 06-12-2010 10:54 PM
Pool room subpanel rayt Electrical 3 10-06-2009 01:17 PM
