Pool 100Amp Subpanel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-10-2012, 04:09 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by electures View Post
And how many pool jobs are lost by $50?
Most of the pools I do have two pumps... that's 100 dollars.
Old 08-10-2012, 04:10 PM   #17
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
And if someone has a pool that has multiple pumps of 1-1/2 to 2 HP I don't think the cost of a few GFI breakers is going to matter.
Old 08-10-2012, 04:12 PM   #18
E2 Electrician
In a bidding war that does not even include the owner but the pool contractor, 100 dollars is a lot.... Besides, why install something that is not needed or required?
Old 08-10-2012, 04:32 PM   #19
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
I'm sorry, using a 25A breaker just to get by the GFI requirement is pretty hack if you ask me.
And I think installing a disposal and DW on the same circuit is hack. But that is another discussion.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-10-2012, 04:36 PM   #20
electures's Avatar
What about the contractor who wires a hundred pools in a year. Now we are talking over $5000. Code is code. If somebody disagrees submit a code change proposal which you won't find in the back of the 1500 pg book.
Old 08-10-2012, 04:37 PM   #21
E2 Electrician
Why? Its perfectly legit... Petey, with that logic, am I a hack because Im on the 2005 and hardwire pumps do not require GFCI protection regardless of breaker size?
Old 08-10-2012, 09:27 PM   #22
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Nope that is following the minimum safety of the enforced code cycle. However, there is also the intent of the NEC to improve human safety as we move forward and is the intent of the language for gfci on pool pump motors. Those pumps do not require 25 amp breakers on dedicated branch circuits. To intentionally seek a loop hole in the NEC at the expense of human safety isn't IMO what the NEC would expect of qualified electricians....nor a customer for that matter.
It's true that an inspector cannot fail it, but it is the idea that you would know why that 25 amp breaker was installed ... to save dollars. Your logic is to save a buck to get a bid by using an unnecessary circuit breaker and probably not inform the customer why you were making that design change. I wonder what the customer would want ...
The Following 2 Users Say Thank You to Stubbie For This Useful Post:
herdfan (08-13-2012), Speedy Petey (08-11-2012)
Old 08-10-2012, 10:39 PM   #23
Electromagician
so offer the customer the option of GFI's at $100 a pop and see how badly he wants them.
I have a box of capacitors that can lower your power bill. just ask me how.
powerfactor is offline   Reply With Quote
Old 08-10-2012, 10:44 PM   #24
E2 Electrician
This is where I SHALL disagree, an EGC trumps a GFCI every time, so with a hard wired pump, I see no issue at all, and the NEC agrees with this... my logic is that I install a LEGAL install... I dont need to do more because of an opinion. GFCI logic is based on money and lobbyists...
Old 08-10-2012, 11:33 PM   #25
electures's Avatar
The customer will want a compliant installation. There is no loop hole. The NEC is clearly written. If you disagree state the code section. That's easy enough.
The Following User Says Thank You to electures For This Useful Post:
stickboy1375 (08-10-2012)
Old 08-10-2012, 11:39 PM   #26
E2 Electrician
Why is this so hard for electricians to comprehend? They choose opinion over code... As if the way they wire is supposedly better? For who though, the customers wallet or their own ego?
Old 08-10-2012, 11:47 PM   #27
" Euro " electrician
frenchelectrican's Avatar
It not that hard to comprehend at all due I am used to French electric codes they are genrally little stricter than NEC.
Oh BTW Our swimming pool pumps all of them have to be on RCD ( GFCI ) no matter if single or triphase motour.
Merci,
Marc
Old 08-10-2012, 11:50 PM   #28
E2 Electrician
Merci,
Marc
But where does the " is it really better logic" come into play? It is a legit install, and perfectly safe.
Old 08-10-2012, 11:53 PM   #29
Master Electrician
code is bare minimum safety wise, i don't see an issue with wanting better than the bare minimum. I give the option to everyone i do work for that they can do it one way and have it cost less or they can spend a little more and have something better than the minimum.
Our code states that all pool equipment has to be wired with gfci protection no matter the motor size, It also has to be permanently wired, so no plugin motors.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-10-2012, 11:55 PM   #30
E2 Electrician
I disagree with that logic, you have a hard wired pump with a EGC, How is a GFCI better than THAT?
Pool subpanel Roskoe General DIY Discussions 0 12-17-2011 08:25 AM
Pool subpanel questions Simbilis Electrical 3 04-23-2011 06:44 PM
Swimming Pool subpanel tedpoppke Electrical 3 08-24-2010 08:59 AM
Adding 100amp Subpanel for basement trajendra_babu Electrical 22 06-12-2010 09:54 PM
Pool room subpanel rayt Electrical 3 10-06-2009 12:17 PM
