On The Pole - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2009, 02:29 PM   #1
Cool
on the pole
i want to hook up the main wires from the electric company and have power to my house and shop how do i split them in the meter box ?
okflipper is offline   Reply With Quote
Old 12-09-2009, 02:44 PM   #2
300zx's Avatar
Post
You need to contact the power co and see what they say.Not a DIY project.If you have room in your panel you could put a sub-panel in the shop .
300zx is offline   Reply With Quote
Old 12-09-2009, 03:02 PM   #3
Are these live wires ?
Are you allowed to work on the Service Feed there ? - we are not here
Is there a breaker or shut off before the Meter box ?
Old 12-09-2009, 03:15 PM   #4
on the pole reply
the wires are not hot the line foreman said i could hook it up and he would inspect it before they turn on my power all i want is a 220 outlet and two 110 oulets on the pole with a shut off switch so i can start working on my temp house with some power. i have done my own elec work many times just never from this point .
Old 12-09-2009, 03:30 PM   #5
Most call me Sparky
Sounds like you want to put up a temporary pole, which requires a meter box, 100 amp weather resistant panel, and a couple of GFCI receptacles, and most importantly a Permit!
Chasm is offline   Reply With Quote
Old 12-09-2009, 03:34 PM   #6
IBEW#363 I am a Rat
Send a message via AIM to thekoolcody
I am not saying that you could not do this your self, but you should bring in a professional that could handle this for you. I am not saying that you could not do it, but my uncle died from doing the same exact project as you are doing.
thekoolcody is offline   Reply With Quote
Old 12-09-2009, 03:50 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
this:
is very different from this:
If all you want is some temp power at the pole, why would you need to split the power anywhere?
You set a temp panel such as chasm stated.
Old 12-09-2009, 03:53 PM   #8
Yup, Temp power setup
Main lugs are supposed to be torqued down to a certain point
So you might need a specific wrench for that
Not certain if all Pro's use one or go by feel
Old 12-09-2009, 04:04 PM   #9
Most call me Sparky
Yeah your right about torquing the main lugs. The specs are for inch lbs. But to be honest I been an electrician for 15 years and have never used one. IMHO i think its more to keep someone from overtightening and possibly breaking the lugs.
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 08:12 AM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 11:21 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Yet another distance from Pole and meter to house question urbanfarmer Electrical 9 05-25-2008 06:38 PM
