Polarity Question!!!! - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2012, 12:49 PM   #1
polarity question!!!!
would an older outlet a bakelite without ground have the same wire orientaion as a new outlet? The old does not seem to have a brass colored side both sides look the same so if I put in a new outlet and put the L side and R side wires from the old onto the L and R side of the new this should be ok right? Just want to make sure the polarity is the same with old and new outlets.
thanks for your help
petros151 is offline   Reply With Quote
Old 09-15-2012, 12:52 PM   #2
Julius793's Avatar
Don't rely on the old outlet wiring test which is hot and which is neutral
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
The Following User Says Thank You to Julius793 For This Useful Post:
petros151 (09-15-2012)
Old 09-15-2012, 01:00 PM   #3
ok thanks! I do not have a meter what is the best way to test?
Old 09-15-2012, 01:08 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
go buy a meter.
Old 09-15-2012, 01:23 PM   #5
Originally Posted by stickboy1375 View Post
go buy a meter.
ok
Old 09-15-2012, 01:25 PM   #6
E2 Electrician
ok
Most likely you will have to run an extension cord from a known, correctly wired receptacle, this way you have a reference point on testing the existing conductors.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 09-15-2012, 01:39 PM   #7
ok thanks!
Old 09-15-2012, 06:11 PM   #8
Rewards Points: 1,514
A two prong receptacle i.e. with no ground pin hole, and both slots the same size, has no rule as to which side is hot and which side is neutral.
It is better not to reuse such receptacles but instead get new "polarized" two prong receptacles whose neutral slot is slightly larger. (If you are ready to restring the branch circuit with grounded cables or add ground fault circuit interrupter protection then you can upgrade to 3 prong receptacles.
The Following User Says Thank You to AllanJ For This Useful Post:
petros151 (09-16-2012)
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
