Polarity Mess - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-05-2008, 09:49 PM   #16
Originally Posted by theatretch85 View Post
Per the NEC these two appliances should be on their own circuits, with the dishwasher running there is the potential to overload the circuit when you flip on the garbage disposal. Also, any above the counter outlets can not be shared off another circuit, meaning the above counter outlets must be on their own 2 circuits. What you are proposing to do would be at least two code violations; what are you doing that you have to rewire these circuits?
OK Dude,
The home was built in 1957 and is a two wire home. (meaning-there is only two wires coming from the main pole to the home. (NO ROUND).
the wires were like that when I moved in, and I just want to put a gfci in place of a reg-recept.
Thanks for your help..
Jinna..
jinna is offline   Reply With Quote
Old 08-05-2008, 09:51 PM   #17
Originally Posted by jinna View Post
OK Dude,
Jinna..
p.s.the wires are not knob&tube--they are regular wires wrap in cloth matl.
Old 08-06-2008, 09:52 AM   #18
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
The old type romex. Good stuff, but it tends to crumble sometimes when you try working with it. If you have more questions, just post them. We'll help.
John
jrclen is offline   Reply With Quote
Old 08-06-2008, 06:22 PM   #19
Rewards Points: 506
Send a message via AIM to theatretch85
OK Dude,
Jinna..
I was simply stating what the NEC code says, and usually if your doing any kinda of remodeling work or disturbing old wiring you are required to bring it up to current code. If your not disturbing it then you should be fine and should not be required to bring it up to the current code. Also, you never included that info in your original post or any subsequent posts after that until I talked about what the NEC code says regarding these circuits.
theatretch85 is offline   Reply With Quote
Old 08-06-2008, 06:26 PM   #20
Rewards Points: 506
OK Dude,
Jinna..
And actually, you have a ground/neutral coming from the pole. If you only have 2 wires up there coming from the pole to your house then you only have 120 volt service, but one of those conductors is a grounded neutral. Your home would not be able to properly operate 120 volt devices without a grounded neutral back to the pole, though 240 volt devices (like electric stoves and dryers) would work just fine (so long as they are not 120/240 volt appliances requiring the neutral). You probably have the 2 prong outlets throughout the house, but you most definitely have a ground from the pole.
Help with a mess James Con Electrical 14 06-19-2008 12:17 AM
Countertop (Formica) mess and husband's ego - HELP! frustratedwife Carpentry 3 11-12-2007 11:10 PM
Decorating my living room - a mess! mikailani Interior Decorating 4 10-21-2007 05:57 PM
reversed polarity. sober4today Electrical 3 07-05-2007 10:02 PM
KITCHEN CUPBOARDS!! in a mess! ashleyc General DIY Discussions 1 07-02-2006 12:55 PM
