PoCo's Wire Sizes - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 06:25 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by rrolleston View Post
We have an 28.8 kw electric tankless water heater and when we have a bunch of stuff running and drawing hot water it can easily go over 100 amps.
Um, you don't think thats an exception to the norm? Whats the sq. ft of your house? i bet your service is too small for that water heater.
Old 05-28-2012, 07:34 PM   #17
JOATMON
ddawg16's Avatar
Rewards Points: 806
I have 200a service and the wires going into my weatherhead look to be #2Awg....NOT 2/0. I would suspect they get off using smaller wire due to the wires being open air and not having the heating issues of wire in a confined space or in conduit.
As for electrical use....don't want to make you guys feel bad...but the highest bill I have ever had was $65. Last month, $43.
Old 05-28-2012, 07:43 PM   #18
E2 Electrician
20 amp service for you.
Old 05-28-2012, 07:48 PM   #19
JOATMON
ddawg16's Avatar
Rewards Points: 806
Yep....until I crank up the compressor or mig welder...
Old 05-28-2012, 09:51 PM   #20
Rewards Points: 266
I checked mine a few years ago and I had 11 amps on one leg and about 2 on the other. I'm with the crowd that says we overbuild our services. If we all drew 100-200 amps continously, we wouldn't be able to afford our electric bill and the utility system couldn't handle it, plain and simple. My block has 6 houses on one 25 kVA, the block across the street has 6 houses also, two of which (that I know of) that have all electric heat. My nieghbor across the street has 8 or 9 breakers for his electric heat. The transformer for that block is also 25 kVA. For those that don't know, 25 kVA is about 100 A @ 240.
junkcollector is offline   Reply With Quote
Old 05-28-2012, 10:02 PM   #21
kevinp22's Avatar
i just want to know how large they have to be so there is no dimming of the ac when it starts.
with my old ac and pre-wiring project it dimmed for like a second and a half.
now with a new ac and rewired house it just blinks - but people still look at me and say, hey what's that, i though you rewired?
kevinp22 is offline   Reply With Quote
Old 05-28-2012, 10:20 PM   #22
E2 Electrician
You'll never get them to accommodate that request, rewiring a house has NOTHING to do with the lights dimming, its a voltage drop issue.
Old 05-28-2012, 11:31 PM   #23
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Yeah we are an exception but still withing an acceptable limit of 200 amp service.
small only 780 square feet mobile home that has been rewired to meet code. When I told them what I wanted to do they ran nice large overhead lines. You have to prove you need it though. But never did upgrade the transformer. . I would say worst case we draw about 150 amps when doing laundry dishes and taking a shower on a cold winter day possibly a little more or less.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 05-28-2012, 11:33 PM   #24
kevinp22's Avatar
yes, i know, but try explaining voltage drop to somewhat disinterested friends and family
Old 05-29-2012, 06:56 AM   #25
E2 Electrician
Excellent point!
Old 05-29-2012, 08:07 AM   #26
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Aerial wires have the wind to act as a heat exchange, kinda like putting a fan over a hot electronic component. So that's probably why they can get away with it.
The high voltage lines that have no insulation are probably even more tolerable as they act as a big heat sink.
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 09:36 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
which GFCI to buy? mike932 Electrical 138 05-15-2011 05:38 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
