Poco Problem Or Mine? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-05-2011, 06:51 PM   #1
Poco problem or mine?
We had a power outage this past week, finally got power back, sort of. Every light in the house flickers and is really dim. The stove clock works but nothing will actually heat up. Water pump for the well isn't working either.
We checked voltage at the main fuse box(pulled out the panel that houses 2 huge fuses), one hot shows 120v, the other 135v, but, and here's where things get weird, when we check both hots it shows 25, not a typo. Shouldn't that reading be the combo of the two?
If we replace that panel then check at main breaker the readings are 115v and 94-98v, but again both hots together is in the 20-25v range. Readings at any outlet in house are low 90v. What the heck is going on? It's got to be an issue on the power companys side right?
Codyormoe is offline   Reply With Quote
Old 11-05-2011, 07:47 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
So call the power company before you allow everything in your home that operates on electricity to be ruined. They all have EMERGENCY numbers. call them.
Old 11-05-2011, 08:37 PM   #3
Electrical Contractor
kbsparky's Avatar
Sounds like you have lost one of the incoming legs of your service. Call the POCO and report it as an outage.
-KB
Old 11-05-2011, 09:09 PM   #4
We called them yesterday not long after the power came back on. But we are where the storm hit last weekend, over 670,000 were without power at one point, there's still over 30,000 out, so response time sucks, it was hard enough just to get a real person on the phone.
Thanks for the answers.
Old 11-06-2011, 07:49 AM   #5
Rewards Points: 1,418
Start by unplugging all electronics, TV's, computers, etc.
Then turn off all 240 volt appliances (including an electric water heater if any). What I suspect will happen is that about half of your circuits (and receptacles) will not be working and the other half will be working okay. To verify that a receptacle is working okay, plug in a 100 watt or so incandescent light (to impose some load) while measuring the voltage. Plug electronics only into a known working receptacle.
Use heavy duty extension cords to connect important appliances such as the refrigerator to working receptacles.
