POCO Primary Voltage - Electrical - DIY Chatroom Home Improvement Forum
Old 08-28-2013, 08:33 AM   #1
Rewards Points: 820
POCO Primary voltage
Hi;
Until I read "The Grid" by Phillip F. Schewe, I thought that the primary lines in a residential area carried 13KV, but in the book, he says 7.2Kv is the standard for primary distribution lines (in residential areas).
So I'm wondering where I got the 13Kv from. Is there a different primary voltage used for industrial, or did I just get wrong info from the getgo?
BTW; I highly recommend this book for anyone who wants a comprehensive education on how the power grid works, its history, and its future, including discussion on reducing CO2 emissions. This has to be the most complete read on the subject I have found, and it is available at your local library.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 08-28-2013, 08:36 AM   #2
joed's Avatar
Rewards Points: 11,576
I imagine it varies by region and load on the lines. I thought they were 4kv.
Old 08-28-2013, 09:10 AM   #3
Rewards Points: 119
The city here is in the process of switching from 7200 to 13000.
KStatefan is offline   Reply With Quote
Old 08-28-2013, 12:47 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,858
7200V is probably the most common primary distribution voltage in non-industrial areas. That is measured phase-to-ground. The corresponding phase-to-phase voltage is 12,480. 13.2kV, 13.8kV, and 14.4kV (double the 7200V standard) are also common. Anything over 15kV to ground requires additional safety precautions and more expensive equipment, so is not commonly used for distribution, only transmission. Old systems were 2400V phase-to-phase (delta configuration) or 4160V phase-to-phase (2400 to ground, but used in a delta configuration). 4160V is no longer commonly used for utility distribution, but is very common for internal use in industrial facilities.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
The Following 3 Users Say Thank You to mpoulton For This Useful Post:
frenchelectrican (08-29-2013), Philly Master (08-28-2013), Speedy Petey (08-28-2013)
Old 08-28-2013, 06:08 PM   #5
Rewards Points: 820
That makes sense. I guess I got the 13KV figure from the phase to phase voltage, not phase to neutral. I used to know how to calculate voltages in multi-phase systems, but have long since forgotten the formula. I do know it involves algebra though
FW
Old 08-28-2013, 08:46 PM   #6
Rewards Points: 334
here in s.c inthe country we have 14.4 kv for distribution,this is REA,i belive SCE&G is 13.2 kv. then some are 4800 volts. this is for the really older areas. some city power is 7.2 kv.some REA'S are still at 7.2 kv.
circuitman is offline   Reply With Quote
Old 08-28-2013, 08:47 PM   #7
Rewards Points: 334
here in s.c inthe country we have 14.4 kv for distribution,this is REA,i belive SCE&G is 13.2 kv. then some are 4800 volts. this is for the really older areas. some city power is 7.2 kv.some REA'S are still at 7.2 kv.this voltage is from phase to neutral
Old 08-29-2013, 01:42 PM   #8
Phase-to-phase is phase-to-ground multiplied by the square root of 3 (approximately 1.73).
Old 08-29-2013, 03:30 PM   #9
Electrical Enthusiast
Rewards Points: 504
This is an interesting thread. I've always heard 7200 and 13kv tossed around. Is there a way to tell simply by seeing the overhead lines/transformers?
Kyle_in_rure is offline   Reply With Quote
Old 08-29-2013, 05:23 PM   #10
Sort of, in general. 7.2kV insulators are often noticeably smaller than higher voltage ones. 4160V insulators were sometimes even smaller still. But you often see 7.2kV lines on larger insulators in some places just due to availability. If the insulators are a single mushroom-shaped thing, then it's probably not more than 7.2kV - although it might be up to 15kV since those insulators are often class-rated for 15kV. If the insulator is taller and has multiple ridges, then it's probably more than 7.2kV - but not always!
The prediction is much more accurate on transmission lines. Suspension disc insulators are good for approximately 10-20kV per disc. This is nonlinear - more discs, more voltage per disc. So a 49kV line may have 4 discs, and a 500kV line 20 discs.
The Following User Says Thank You to mpoulton For This Useful Post:
Kyle_in_rure (08-29-2013)
Old 08-30-2013, 01:40 AM   #11
Oso954's Avatar
Rewards Points: 428
That takes care of the voltage, but a few other factors come into play.
Disc failures happen thru natural or man-made causes. Throw in a few extra to allow for it. On a 500kv, we went 4 extra.
Pollution (dust, salt, ash, stack emissions, etc) you might add any thing between 0 and 20 depending on the evaluation.
So, in the heaviest pollution areas, you might have 44 discs total.
That is at sea level. Toss in another 3 percent for every 1000 feet of elevation. Always round up. So, at 3000 feet you could end up with as many as 48 discs in every string. (30-32 was more typical for that elevation).
Oso954 is online now   Reply With Quote
The Following 2 Users Say Thank You to Oso954 For This Useful Post:
Kyle_in_rure (08-30-2013), mpoulton (08-30-2013)
Old 09-04-2013, 09:12 AM   #12
Rewards Points: 820
What type of insulators are used for those long-distance lines that run as high as 1.2MV (million volts)?
FW
Old 09-04-2013, 12:54 PM   #13
FW
The same type of suspension discs as for a 345kV line, but many more of them.
Old 09-04-2013, 02:16 PM   #14
Rewards Points: 446
Ahhhhhh nothing like the smell of ozone in the foggy morning near the ocean and every salt covered insulator stack has arcing. Was never an electrician by trade, but often wondered what was the safe distance to keep between me and the pole on those mornings walking from the parking lot to the ship.
old_squid is offline   Reply With Quote
Condensate Drain Line Mystery (pan full but no primary clog?) CarrieLP HVAC 21 04-05-2012 12:07 AM
Mast and weatherhead pulled from house, conflicting information from POCO subcontract SleepnZJ Electrical 1 11-02-2011 10:39 PM
Phantom voltage -- I'm completely stumped kb01 Electrical 2 12-24-2010 07:44 PM
Low Voltage Post Light b_corwin Landscaping & Lawn Care 1 10-16-2009 10:20 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
