PoCo People, Please Interpret - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-23-2012, 06:33 PM   #16
Originally Posted by Jim Port View Post
Task: Change pole mounted transformer.
Crew A: 6 hours
Crew B: 2 hours
Answer, 2<6, Crew B is faster.
Comparisons, A+
Congrats, unless you used your fingers to see which was more.
Next question: what is 6+2?
And what could (6+2)/2 mean?
Old 07-23-2012, 07:06 PM   #17
raylo32's Avatar
Rewards Points: 1,226
Watch out for the noise that cheap gens make. A lot of folks say it doesn't matter since it is just a backup but during an outage walk around and listen. Some of them are so loud they would be hard to tolerate even running intermittently. Depending on your proximity the neighbors might not be too happy either. More to the equation than cents per KW.
Originally Posted by Yoyizit View Post
Thanks.
A Generac at Costco is going for 17 cents/W, just above HF's 10 cents/w.
In the fall I may buy the thing.
Live long and prosper.
raylo32 is online now   Reply With Quote
Old 07-23-2012, 07:30 PM   #18
I run my whole house off my Miller legend welder/generator , albeit have to move a few circuits around. Has worked for us since before Hurricaine Gloria in 1985!
Amazingglazier is offline   Reply With Quote
Old 07-23-2012, 10:26 PM   #19
Licensed electrician
Rewards Points: 1,028
Comparisons, A+
Just more irrelevant numbers. Why do you think they would mean anything?
Old 07-24-2012, 10:16 AM   #20
Why does one care about the average of the two crew times when comparing the two crews performance?
Evstarr is offline   Reply With Quote
Old 07-24-2012, 03:26 PM   #21
I get a catalog that had one of these air-powered horns that use a canister. It said: 120 dB at 10' and works up to a half mile.
Using a 6 dB reduction for each doubling of distance this works out to something like 70 dB at a half mile, so if you build a doghouse around this thing with a box fan for cooling you may be able to get it down to this level, which I assume is background level for some environments.
Old 07-24-2012, 06:22 PM   #22
I'll assume your motives for asking questions are different from Mr. Port.
You might try searching on
"management science"
"quality control"
ANOVA
quartiles
"standard deviation"
"normal distribution"
Computing averages are the first baby steps for evaluating performance.
Old 07-24-2012, 06:23 PM   #23
How many kw does it put out?
Hard start kits installed in your ACs?
It seems with 5kw you can't do it all and with 20 kw you hardly ever run it to full capacity.
Why HVAC people want to replace unit and not coil? pcumming HVAC 4 05-21-2011 10:57 PM
Paying people to wreck my lawn turbomangt Landscaping & Lawn Care 7 04-17-2011 09:08 AM
Drywalling: which way to go: 2 people or 1 person and a drywall lifter? KUIPORNG Remodeling 19 10-24-2006 09:42 AM
People on here fishing... DaveH General DIY Discussions 19 08-02-2006 01:55 PM
Hello DIY people - just introducing myself leftoverjoe Introductions 3 06-02-2006 08:13 PM
