#1 |
Po Boy Finally Buys A Washer/Dryer
Ya know when your g/f or wife says, 'Don't you DARE talk down to me?'... well, I AIN'T your g/f or wife but what i IS is so DYI challenged that anything but the most basic explanation will cause my brain to short circuit.
To prove how DYI-tarded I am, I bought a used staking washer/dryer because it was what I could afford.. but now I can't plug it in. The plug is a large crows-foot deal but my outlets are standard USA deals. I know it can't be as simple as changing the cord to a standard 3-prong. KENMORE STACKING WASHER/DRYER MODEL NO: 417.90802992 WASHER 120/240V DRYER 240V APPROX 4 YEARS OLD EXCELLENT CONDITION ... the part number on the plug is E11808 Any suggestions (unless i starts with 'shove it up your') are appreciated. Thank you - Mick |
#2 |
Xtreme DIY'r
Do you have a standard 240v outlet to plug this into ?
And does the outlet take a 3 prong or 4 prong plug ? and where are you hooking this up..CA or Ireland ? |
#3 |
thank you, Scuba-Dave, for taking the time to respond.
And now, to show the depth of my ignorance - If a standard 240v outlet is a 3-prong plain ol American one (like for a fridge), then yes I do This is going into my apt. in California. |
#4 |
Xtreme DIY'r
A fridge is not 240v
This is a standard 120v outlet If this is all you have then you can't plug it in
#5 |
Xtreme DIY'r
240v 4 prong outlet
![]() 240v 3 prong outlet
#6 |
ah.. that's all I have (standard 120v outlet) and the washer/dryer needs 240v 3 prong outlet
is there a converter/transformer i can buy? if I was in Ireland I'd just take it as is and pound it in with a hammer
#7 |
I found an article that explains how to do to opposite (use 110v in 220-240v outlets) but nothing that addresses my problem.
Would an electrician be able to install such an outlet? |
#8 |
Xtreme DIY'r
Since this is an Apt you would need to check with the landlord on having a 240v outlet run
Hopefully there is enough power to run a circuit But I have seen some Apts that only have 60a power & can't handle a dryer connection |
#9 |
the wire there now will not carry the power you need. you will need a new wire from panel to that location
The older I get the better I was |
#10 |
Yes, and you should call one before you hurt yourself or someone else.
| Tags |
dryers, electric wiring, outlets, plug, washing machine ![]() |
| Display Modes | |
| Hot Water Turning Cold - Could it be the washer/dryer? | kissiffer4 | Plumbing | 3 | 01-28-2010 05:47 PM |
| Finally a DIY with HVAC! | Guido | Introductions | 4 | 01-22-2008 08:31 PM |
| Washer/Dryer Hookup? | Ms Nikki | Plumbing | 5 | 11-07-2007 08:58 PM |
| How to handle circuit for washer/dryer relocation? | KUIPORNG | Electrical | 9 | 06-16-2006 10:09 AM |
| relocate washer/dryer | krtw | Remodeling | 2 | 01-15-2006 03:39 AM |
