-   -   Po Boy Finally Buys A Washer/Dryer (http://www.diychatroom.com/f18/po-boy-finally-buys-washer-dryer-65013/)
Mickk3 02-21-2010 03:33 PM
Ya know when your g/f or wife says, 'Don't you DARE talk down to me?'... well, I AIN'T your g/f or wife but what i IS is so DYI challenged that anything but the most basic explanation will cause my brain to short circuit.
To prove how DYI-tarded I am, I bought a used staking washer/dryer because it was what I could afford.. but now I can't plug it in. The plug is a large crows-foot deal but my outlets are standard USA deals.
I know it can't be as simple as changing the cord to a standard 3-prong.
KENMORE STACKING WASHER/DRYER MODEL NO: 417.90802992
WASHER 120/240V
DRYER 240V
APPROX 4 YEARS OLD
EXCELLENT CONDITION
... the part number on the plug is E11808
Any suggestions (unless i starts with 'shove it up your') are appreciated.
Thank you - Mick
Scuba_Dave 02-21-2010 04:02 PM
Do you have a standard 240v outlet to plug this into ?
And does the outlet take a 3 prong or 4 prong plug ?
and where are you hooking this up..CA or Ireland ?
Mickk3 02-21-2010 04:11 PM
thank you, Scuba-Dave, for taking the time to respond.
And now, to show the depth of my ignorance -
If a standard 240v outlet is a 3-prong plain ol American one (like for a fridge), then yes I do
This is going into my apt. in California.
Scuba_Dave 02-21-2010 04:36 PM
A fridge is not 240v
This is a standard 120v outlet
If this is all you have then you can't plug it in
http://www.smarthomeusa.com/Products...geSAURD30W.jpg
Scuba_Dave 02-21-2010 04:38 PM
240v 4 prong outlet
http://applianceguru.com/ranges/4prong_range_outlet.jpg
240v 3 prong outlet
http://applianceguru.com/dryers/dryer_outlet.jpg
Mickk3 02-21-2010 04:45 PM
ah.. that's all I have (standard 120v outlet) and the washer/dryer needs 240v 3 prong outlet
is there a converter/transformer i can buy?
if I was in Ireland I'd just take it as is and pound it in with a hammer :eek:
Mickk3 02-21-2010 04:53 PM
I found an article that explains how to do to opposite (use 110v in 220-240v outlets) but nothing that addresses my problem.
Would an electrician be able to install such an outlet?
Scuba_Dave 02-21-2010 04:57 PM
Since this is an Apt you would need to check with the landlord on having a 240v outlet run
Hopefully there is enough power to run a circuit
But I have seen some Apts that only have 60a power & can't handle a dryer connection
tpolk 02-21-2010 08:09 PM
the wire there now will not carry the power you need. you will need a new wire from panel to that location
J. V. 02-22-2010 11:45 AM
Yes, and you should call one before you hurt yourself or someone else.
