Plywood Behind Electric Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2012, 12:57 PM   #1
Rewards Points: 202
plywood behind electric panel
I would like to mount my existing main electric panel onto some 3/4" plywood. Currently is it mounted to studs. Can I just shut off the main breaker and unscrew the panel and slide a piece of plywood behind it, while obviously avoiding the main lugs? Or do I need to call the power company to shut off the power?
Thanks!
benleef is offline   Reply With Quote
Old 11-13-2012, 01:00 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Is it mounted between studs or on top of the studs?
Do you have an outside disconeect?
I don't think I would attempt this with the mains still entergized.
Old 11-13-2012, 01:04 PM   #3
Rewards Points: 202
It is actually an upgraded panel. The old panel was obviously smaller and mounted on wood attached to the studs. This panel is half on that wood and half on the studs. Obviously the electrician was lazy. I'd like to mount it all on 3/4" plywood for obvious reasons. There is no disconnect on the outside, just the meter.
Old 11-13-2012, 01:07 PM   #4
jbfan's Avatar
Rewards Points: 478
Just make sure that you stay away from the incoming wires.
Old 11-13-2012, 01:48 PM   #5
joed's Avatar
Rewards Points: 12,862
And don't drop the screws onto any live parts.
Old 11-13-2012, 03:27 PM   #6
Rewards Points: 202
Thanks! What is the process of getting the power company to turn the power off and then back on? Perhaps it will be worth it just so I don't have to worry about the risks, no matter how remote.
Old 11-13-2012, 06:42 PM   #7
Missouri Bound's Avatar
Very simple....call them and WAIT......when you are done call them and WAIT...I won't even begin to speculate how long the wait is....but don't stock up on any perishables first.......
Do you want it your way or the right way?
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
electric service panel Gtuff Electrical 5 01-30-2012 03:07 PM
Main Electric Panel Help Redrum Ninja Electrical 13 10-22-2011 07:28 PM
Electric panel enclosure question globus999 Electrical 6 11-23-2010 09:30 PM
breaker panel question chadvavra Electrical 11 08-10-2007 09:20 AM
