Plumbing Over / Under Wiring Runs - Electrical - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 10:28 AM   #1
Rewards Points: 270
plumbing over / under wiring runs
not sure if this questions belongs in the electrical or plumbing forum. I recently wired my addition using a subpanel and home-runs to all devices.
I took advantage of some 2x6 runners that cross under the floor joists mid-span (bracing) in my crawlspace to run the main 100 amp panel wire plus a few other runs (where there was room) so as not to have to drill the joists in tight spots (e.g. 1' o/c)
Now I'm under there planning out some new plumbing runs (pex) and inevitably there are some spots where the pex will cross these running boards / wiring runs.
Once again probably overthinking things, but I'm just curious - is it a "best practice" to keep plumbing under the wiring where the 2 meet (thinking about things like drips from sweaty pipes, etc. - not sure there is even an issue with pex). Does it make any difference?
thanks
rtoni is offline   Reply With Quote
Old 05-16-2011, 11:02 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Not an issue.
Old 05-16-2011, 11:32 AM   #3
Rewards Points: 270
jbfan thanks for the sanity check...
trying to get educated about house wiring ChrisJJ Electrical 7 08-08-2010 02:23 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Wiring garages/outdoor The Right Way? lanispet Electrical 6 04-04-2008 11:04 AM
Remodeling upper...existing runs to the basement? wease Electrical 3 02-11-2007 10:49 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
