Plugs On Bell Boxes - Electrical - DIY Chatroom Home Improvement Forum
Old 07-05-2013, 02:33 PM   #1
ericmunyon12345's Avatar
Plugs on bell boxes
Quick opinion question: it says to silicon the plugs on a bell box for wet location. If it's not going to get real wet, like under a garage peak overhang, I just use several wraps of Teflon tape. I put this on the lamp holders too (not a good ground anyway due to coating, so I DO use the grounding screws on the box, cover, and lamp holders). Anyone say Teflon tape is a terrible idea? Other tips?
ericmunyon12345 is offline   Reply With Quote
Old 07-05-2013, 03:13 PM   #2
MarginallyQualified
Rewards Points: 2,464
Ive never done either
Old 07-05-2013, 04:59 PM   #3
Licensed electrician
Rewards Points: 1,486
I caulk the ones on the top of the box, if any.
Old 07-05-2013, 05:20 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
If you can't use the caulk do to its location, put the plug in and then put a good size dolup on your finger and cover the plug.
sublime2 is offline   Reply With Quote
Old 07-05-2013, 08:40 PM   #5
" Euro " electrician
frenchelectrican's Avatar
I useally chalk the top half but almost never on bottom half ( unless subject ot spraying water then I will seal up the whole thing )
And of course drill out a small 1 or 2 mm hole on bottom of it that will assit any water to drain out.( unless it is under " damp location " I may let it slide depending on the set up )
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
ericmunyon12345 (07-05-2013)
Old 07-06-2013, 11:01 AM   #6
Rewards Points: 126
I drill a hole in the bottom. A small hole.
Actually I don't, but I would do that before trying to seal it up.
2 breakers with black and red hots for only 2 plugs in kitchen. Y so many? Runestone Electrical 19 10-19-2012 05:35 AM
grounding metal junction boxes simanco Electrical 3 07-27-2012 05:22 PM
cutting plugs off would violate... Daneel Electrical 9 06-05-2011 04:21 AM
Can I cover unwanted electrical boxes (ie switch box) with drywall?? DanDaMan Electrical 15 03-07-2011 02:59 AM
KO plugs are dangerous! Ultrarunner2017 Electrical 10 11-25-2008 06:57 PM
