-   -   Plugs on bell boxes (http://www.diychatroom.com/f18/plugs-bell-boxes-183099/)
ericmunyon12345 07-05-2013 02:33 PM
Plugs on bell boxes
1 Attachment(s)
Quick opinion question: it says to silicon the plugs on a bell box for wet location. If it's not going to get real wet, like under a garage peak overhang, I just use several wraps of Teflon tape. I put this on the lamp holders too (not a good ground anyway due to coating, so I DO use the grounding screws on the box, cover, and lamp holders). Anyone say Teflon tape is a terrible idea? Other tips?
TarheelTerp 07-05-2013 03:13 PM
Ive never done either
Jim Port 07-05-2013 04:59 PM
I caulk the ones on the top of the box, if any.
sublime2 07-05-2013 05:20 PM
If you can't use the caulk do to its location, put the plug in and then put a good size dolup on your finger and cover the plug.
frenchelectrican 07-05-2013 08:40 PM
I useally chalk the top half but almost never on bottom half ( unless subject ot spraying water then I will seal up the whole thing )
And of course drill out a small 1 or 2 mm hole on bottom of it that will assit any water to drain out.( unless it is under " damp location " I may let it slide depending on the set up )
Merci,
Marc
J. V. 07-06-2013 11:01 AM
I drill a hole in the bottom. A small hole.
Actually I don't, but I would do that before trying to seal it up.
