Old 10-17-2007, 08:27 PM   #1
sil
Plugging power cord in a non-grounded outlet
I tested my 3 prong outlet only to find out it was not grounded. Do I need to have it grounded in order to plug all my audio visual including my plasma into the outlet?
Is it most likely that I would need to re-wire to copper in order to install a grounded outlet? Is it most likely aluminum wiring in my existing outlet?
sil is offline   Reply With Quote
Old 10-17-2007, 10:13 PM   #2
An ungrounded outlet could be copper or aluminum. Same with a grounded outlet. It probably just means that the cable feeding that outlet only has 2 wires (hot and neutral, no bare ground wire).
I'd shut off the circuit, remove the outlet, and look at the wires in there to confirm this. If this is indeed the case, then the fix would be to replace that cable back to the panel with modern 2-conductor, plus ground romex cable.
NateHanson is offline   Reply With Quote
Old 10-18-2007, 12:02 AM   #3
It could be grounded elsewhere on the circuit though...
ajan246 is offline   Reply With Quote
Old 10-18-2007, 01:13 AM   #4
Another thing to consider when looking at the duplex receptacle is the polarity. Because it wasn't grounded, it is also possible that the person who hooked it up crossed the polarity.
sluggermike is offline   Reply With Quote
Old 10-18-2007, 01:23 PM   #5
J. V.'s Avatar
I would'nt plug a big screen TV into a non-grounded receptacle. Run a new NM cable with ground. Once you start adding components to the system, you will be best served to have a dedicated circuit.
extension cord draining power? mt232 Electrical 14 05-25-2011 04:37 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Outlet and light pigtailed to power. ok? skellies Electrical 2 06-24-2006 02:08 PM
