Plugging Fixture Into Light Socket? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 07:17 PM   #1
Rewards Points: 986
Plugging fixture into light socket?
I have two light sockets on my basement ceiling, and I have two fluorescent fixtures with plugs on them.
I can buy adaptors that let you plug into a socket, or I could replace the existing light socket with new boxes and outlets. The first will be much easier and cost about 20% of the second, but the second will be grounded.
Is being grounded worth the time and money?
Toller is offline   Reply With Quote
Old 04-09-2013, 07:41 PM   #2
seansy59's Avatar
Rewards Points: 258
Yes. grounding means A LOT in today's world. Grounding could mean the difference between a breaker tripping or you being electrocuted/dancing uncontrollably like a monkey if there was a short in one of the lights.
If it is one of those basic porcelain light fixtures, just remove the fixture, wire in a basic $1 outlet, and put a $1 octagonal box outlet cover over it. No need to change the box.
Personally $2-$3 and an added ground is worth the extra $1 to me....
seansy59 is offline   Reply With Quote
Old 04-10-2013, 01:02 AM   #3
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
Is staying alive worth it?
I never liked those "adaptors" to use an old style porcellain light bulb socket for an outlet, especially an ungrounded one, even more especially in the basement.
Run a piece of conduit with a ground to a real outlet and be safe.
RWolff is offline   Reply With Quote
Old 04-10-2013, 01:30 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,976
Funny.....how many decades did our country survive on just 2 wire AC?
On a serious note....the 'proper' choice would be to use a ground.
On a 'realistic' note....assuming there is no wiring mistakes in the fixture.....no one will die....if unsure....don't touch the fixture while power is one.
Old 04-10-2013, 05:45 AM   #5
Rewards Points: 347
Some people didn't survive; that's why things have changed. And while I think we may have gone a bit overboard, it is proven over and over that these changes save lives.
To the OP, post #2 is relatively easy, is low cost, will accomplish the goal of a ground, and will look decent too.
al_smelter is offline   Reply With Quote
Old 04-10-2013, 05:46 AM   #6
Rewards Points: 2,516
Go with option number #2.
4" square box, 4" raised duplex cover and a receptacle
hammerlane is offline   Reply With Quote
Old 04-12-2013, 02:52 AM   #7
Rewards Points: 192
Just curious about that last picture. Assuming that the current NM-B colors are in affect. Why is there a 12AWG (yellow) cable feeding a box and two 14AWG (white) cables coming out.
Just curious.
bcgfdc3 is offline   Reply With Quote
Old 04-12-2013, 08:06 AM   #8
Just curious.
All three cables have #12 conductors.
The left top white is 12-2 from the breaker and bringing power into the j-box.
The left bottom white is 12-2 and is taking power downsteam to other receptacles for lights.
The yellow is 12-3 and is taking power to switches.
Old 04-12-2013, 08:11 AM   #9
Rewards Points: 347
I still have a mile or two of the white #12 NM, bought many years ago and stored for a rainy day. As I recall, I paid about 20 bucks for a 250 ft roll.
Old 04-12-2013, 08:14 AM   #10
Yes...the morale of the story is pay no attention to the color of cable sheathing Daniel-Son
Old 04-12-2013, 09:38 AM   #11
JOATMON
ddawg16's Avatar
But don't you know that the white NM has an expiration date?
Old 04-12-2013, 11:01 AM   #12
Rewards Points: 347
Wow, I didn't know that. I suppose I should pay someone to get it out of my loft. Wonder what they'd charge me to get rid of 50 or so rolls?
Old 04-12-2013, 11:30 AM   #13
Rewards Points: 35
Another reason to make sure that a fluorescent fixture is supplied with a ground connection is that many of the new electronic ballasts require a connection between the ballast and ground (green or bare wire) in order to function. These ballasts utilize a capacitive conduction path to ground in order to start the fluorescent lights.
czars is offline   Reply With Quote
Covering the light fixture electric box firsttimeremode Electrical 57 09-18-2012 12:50 PM
Electrical Short in New Light Fixture amateur1 Electrical 14 04-10-2012 07:45 PM
Circuit Breaker Tripping when I turn on kitchen light fixture hiker23 Electrical 2 02-04-2012 02:30 PM
trying to figure out Knob & Tube wiring on old light fixture dalethompson Electrical 16 02-02-2012 08:42 PM
HELP! Wiring 2 switches with new light fixture michugana Electrical 7 04-10-2011 06:49 PM
