Old 01-16-2009, 04:07 PM   #1
Plug for Whirlpool
I'm installing a 20 amp recepticle for a new whirlpool tub. Is there any reason I can't put the plug facing the tub? I can't fit it on a 2x4 wall facing away from the tub because it will be covered by sheet rock
MikeyP is offline   Reply With Quote
Old 01-16-2009, 04:54 PM   #2
dSilanskas's Avatar
Plug for Whirlpool
Yes usually you put the plug under the tub where the motor is located. Just make sure its GFCI
dSilanskas is offline   Reply With Quote
Old 01-16-2009, 04:59 PM   #3
Electrical Contractor
wirenut1110's Avatar
Send a message via AIM to wirenut1110
Plug for Whirlpool
I usually install a dead front GFI on the wall in the bathroom and feed a duplex receptacle under the tub. That way, if it happens to trip, (and it probably will) you won't have to remove the access panel to reset it.
wirenut1110 is offline   Reply With Quote
Old 01-16-2009, 08:36 PM   #4
Plug for Whirlpool
I plan on putting in GFI breaker instead. Does that sound ok?
Old 01-16-2009, 08:45 PM   #5
Plug for Whirlpool
Yeah.
rgsgww is offline   Reply With Quote
20 amp plug MikeyP Electrical 6 01-03-2009 10:04 PM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 08:44 PM
GFI Plug Troubleshooting bryanchr Electrical 4 08-22-2008 06:28 PM
Is it safe to plug in this flourescent fixture? doofalot Electrical 2 08-16-2008 02:27 PM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 09:07 PM
