-   -   Plug for Whirlpool (http://www.diychatroom.com/f18/plug-whirlpool-36077/)
MikeyP 01-16-2009 04:07 PM
Plug for Whirlpool
I'm installing a 20 amp recepticle for a new whirlpool tub. Is there any reason I can't put the plug facing the tub? I can't fit it on a 2x4 wall facing away from the tub because it will be covered by sheet rock
dSilanskas 01-16-2009 04:54 PM
Yes usually you put the plug under the tub where the motor is located. Just make sure its GFCI :laughing:
wirenut1110 01-16-2009 04:59 PM
I usually install a dead front GFI on the wall in the bathroom and feed a duplex receptacle under the tub. That way, if it happens to trip, (and it probably will) you won't have to remove the access panel to reset it.
MikeyP 01-16-2009 08:36 PM
I plan on putting in GFI breaker instead. Does that sound ok?
rgsgww 01-16-2009 08:45 PM
Yeah.
