Plug In Transformer Baffles Me - Electrical - DIY Chatroom Home Improvement Forum
Old 03-04-2010, 09:57 PM   #1
Rewards Points: 113
plug in transformer baffles me
I have a plug in type 24 volt transformer. Both prongs are the same size--not retricting how it could be plugged into the outlet. I have a sensor that beeps when there is current at the sensor tip. I measure 27.5 volts across the terminals.
Here is what I don't understand----my current sensor indicates that both terminals are hot regardless of how the transformer is plugged into the outlet. How can this be? To be sure my sensor wasn't picking up a reading thru the body, I attached an 8" wire to each terminal and got the same indication that both are hot. One terminal has a "R" in its vicinity. Shouldn't the other be the neutral and no current to it?
Captflx is offline   Reply With Quote
Old 03-04-2010, 10:12 PM   #2
Rewards Points: 1,514
Most household transformers (doorbell, electric shaver, model train, etc.) have secondaries isolated from their primaries, that is, neither output terminal is "automatically" connected to neutral when the transformer is plugged in.
This way, also, it doesn't make any difference which way the plug is inserted into the receptacle.
Transformer output current does not return to the main panel; rather the current just has to return to the other terminal on the transformer's output.
Old 03-05-2010, 09:27 PM   #3
Rewards Points: 113
Thanks AllanJ.
removed old romex (added new wire) and added a plug doesn't work now? Limit54 Electrical 9 11-08-2009 09:03 PM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 09:44 AM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 09:49 AM
20 amp plug MikeyP Electrical 6 01-03-2009 09:04 PM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 07:44 PM
