Plug Removal Help. - Electrical - DIY Chatroom Home Improvement Forum
Old 08-13-2011, 07:28 AM   #1
Plug removal help.
Hi-
https://sites.google.com/site/mypictureskrc/
How do I remove a plug like this? This is a DVD player that blew a fuse so I put a new one in and it blew that too. The man at Radio Shack said if the fuse blew it is between the fuse and the electric source. If that is true this is the next part to replace.
Any thoughts?
Thanks,
k
krc777 is offline   Reply With Quote
Old 08-13-2011, 08:23 AM   #2
Rewards Points: 6,652
Need something better for the second photo, but the way you remove those D Plugs, is just pull on it. If it does not pull out, that means either melted in the female end, or got glued in some how.
Best way to take a photo, is head on, not on angles, due to the two photos you took do not give a really great presentation of the problem. When you take a photo for something like you question, it is easier to show people the problem, by taking a end shot of the plug & device, and for the second, a top view.
Old 08-13-2011, 09:22 AM   #3
Electromagician
the man at radio shack is an idiot.
powerfactor is offline   Reply With Quote
Old 08-13-2011, 09:43 AM   #4
You think. I thought that the drones at BB were the worst. Hopefully this one Ratshack employee is not like the rest of them at that location.
Old 08-13-2011, 10:57 AM   #5
So you mean the RS guy is wrong and it is not between the electric source and the fuse?
I will take new photos as suggested too.
thanks!
Old 08-13-2011, 11:10 AM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
A fuse or breaker trips because of an overload downstream.
If the fuse is blowing inside the dvd player, then it is a problem with the player.
Have you plugged something into the receptale to see if it works?
Old 08-13-2011, 11:21 AM   #7
New photos. I tried to take every angle straight on.
thanks.
Old 08-13-2011, 11:24 AM   #8
JB-
the player was plugged into a surge protector and there are still units, tv plugged in to that SP and working fine.
If it is now the power source what is my next step to locating the problem?
Old 08-13-2011, 11:26 AM   #9
jbfan's Avatar
Rewards Points: 478
The problem may be the recifier that changes AC voltage to DC voltage.
Unless you know how to test and troubleshoot circuit boards, it is cheaper to replace the player.
I don't even test my electroincs past the fuse any more, just to time consuming.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
gregzoll (08-13-2011), krc777 (08-13-2011)
Old 08-13-2011, 01:42 PM   #10
My next step is to go to Wally world and buy a new one.
Master of Cold is offline   Reply With Quote
Help converting dryer plug to welder plug. RodBarney Electrical 18 07-22-2011 07:18 PM
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 07:48 AM
Replacement plug for an old box freezer brich Electrical 1 05-11-2010 06:44 AM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 09:49 AM
20 amp plug MikeyP Electrical 6 01-03-2009 09:04 PM
