Plug In Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-23-2008, 08:44 AM   #1
plug in question
hello,im putting 1/4 inch sheetrock over existing 3/8 sheetrock.does anybody know what i can do to shim out exsting plugins and light switches so that the plates are flush.is this something that i can do after i install the sheetrock or should i do it first.any help is appteciated.thanks again from east washington state.
GLASSMAN1 is offline   Reply With Quote
Old 02-23-2008, 09:02 AM   #2
Ideally, you should try to cut the holes for the receptacles and switches a little small so the ears of the devices are resting on the drywall. This usually involves unsrewing the devices so they can be tilted through the new holes. If that doesn't work out too well, there are spacers that are made for this type of problem:
http://contractorservices.homedepot....1-b6326ddc17dc
jerryh3 is offline   Reply With Quote
Old 02-23-2008, 09:29 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
I use Arlington BE-1's for this purpose.
Old 02-23-2008, 09:50 AM   #4
I had not seen these. Looks much better. Do they need oversized plates?
Old 02-23-2008, 09:53 AM   #5
When is fishing season?
CowboyAndy's Avatar
Even if the sheetrock is cut tight enough for the ears of the recep to rest on, an extension ring must be used because the box won't be flush with the sheetrock... NEC 370.20
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 02-23-2008, 09:58 AM   #6
Learn something new every day. Are you sure it's 370.20? I couldn't find that in the book. 314.20, maybe?
Old 02-23-2008, 10:03 AM   #7
Speedy Petey Can You Explain A Little How To Install?
Old 02-23-2008, 10:20 AM   #8
CowboyAndy's Avatar
Ya, I realized that it might not have been the correct article, I only have access to the online edition of the code and I can't get it to open for some reason. I am looking into it now.
MY HOUSE OWNS ME!
Old 02-23-2008, 10:27 AM   #9
CowboyAndy's Avatar
This is the link I normally use for the online edition of the code... can someone else try it and see if it works for them? I keep getting a java error.
http://www.nfpa.org/freecodes/free_a....asp?id=7008SB
MY HOUSE OWNS ME!
Old 02-23-2008, 10:40 AM   #10
Electrician
Just remember that 1/4" is the most a box can be setback from the finish, anything more than that will require a box extender...art. 314.20
chris75 is offline   Reply With Quote
Old 02-23-2008, 11:37 AM   #11
Jerry & Glass,
No, they do not need OS plates.
They slip right into the box before the device. Simple as that.
Old 02-23-2008, 12:18 PM   #12
Sparrky
no problem. . .roto-zip out the exiting drywall around the box...install correct depth mudring..then roto-zip the area for only the face of the mud ring . . . . .it'll be good to go
Kingsmurf
Kingsmurf is offline   Reply With Quote
Electric Dryer wiring/plug question SpaceCrawler Electrical 6 08-26-2008 05:33 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 09:07 PM
Plug Sockets - Basic Question chris_stfc Electrical 6 12-25-2007 05:03 PM
Switching from light socket to plug - stupid question CGofMP Electrical 5 03-25-2005 10:48 PM
