Plug In Power Box 240v Help Needed Asap - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-31-2012, 08:35 PM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Here's the part you are not going to like...
You cannot hook up that timer setup legally. You cannot use SO cord as a permanent wiring method. You would have to hard wire that for it to be considered legal. If you do that, you are pushing the 6 disconnect rule with what is already installed. You would need to rework just about everything you have.
The Following User Says Thank You to k_buz For This Useful Post:
CeoHappy (11-01-2012)
Old 10-31-2012, 08:40 PM   #17
jrclen's Avatar
Rewards Points: 514
How would you feel about wiring this assembly into your panel correctly using 4 #10 wires, and forgetting that plug and cord which is completely wrong?
Not that the plug is the only problem with this project, but it's the most glaring because it is 3 prong rather than 4.
John
jrclen is offline   Reply With Quote
Old 10-31-2012, 11:46 PM   #18
Well even if it isn't up to code, it is only going to run for a hour til I plug them into the right outlets. So if you know how to fix it let me know, I understand the risk. thank you again K buz.
CeoHappy is offline   Reply With Quote
Old 11-01-2012, 08:12 PM   #19
Plug and play.
40 amp system includes four 240 volt outlets and four 110 volt outlets. Timer controls 240 volt outlets.
50 amp system includes six 240 volt outlets and eight 110 volt outlets. Timer controls 240 volt outlets.
All standard package assemblies include:
Intermatic 240 volt timers. No relays to stick or fail. Parts and accessories readily available at any home center.
All circuit breakers. No fuses. Double grounded outlets for safety. All industrial components.
All 10 ga. oversized wiring for safety and easy user upgrade to larger capacity.
Comes with 6 foot long 3 prong 50 amp dryer plug or installed 6 foot cable with bare ends for user connection to power source.
Longer power supply cords with any type of plug available upon request, or a simple pre-wired 240 volt female plug installed in main panel for user connection.
Custom and advanced systems for special applications.
Main panel and sub panel assemblies available for multiple room use. Can be hard-wired or use convenient plug connection for ease of installation.
Optional “ultra safe 240 volt” configuration available on any system. Each bank of four 240 volt outlets is controlled by a separate timer and separate circuit breaker.
Timers for all or part of 110 volt outlets
Compact assemblies mounted on plastic panels or spread out outlet systems. Just furnish us with length of wire runs.
Flexible design. Focus more on reliability and ease of use than fancy boxes and blinking lights. You have better things to do than worry about your power. Locally produced using only the best available components.
Old 11-01-2012, 08:13 PM   #20
Found this is this legal and will it work looks just like mine almost and plugs into dry outlet.
Old 11-01-2012, 08:44 PM   #21
k_buz's Avatar
If its not UL (or equivalent) listed and cord connected, it is not legal for use as permanent wiring.
Old 11-01-2012, 09:04 PM   #22
So my question is, what are you hoping to end up with? What I'm trying to say is, what is the end goal here? What do you want/need to run for an hour until you plug them in somewhere else. I think it would help these pro's if they better understood what you were trying to accomplish.
southernkilowat is offline   Reply With Quote
Old 11-01-2012, 09:13 PM   #23
k_buz's Avatar
The "funny" part is that all he needed was a timer and a couple contactors. I see a minimum of $200 in parts for what he bought. I'll bet you could do it cheaper and legal.
Old 11-01-2012, 09:35 PM   #24
jrclen's Avatar
Rewards Points: 514
No it is not legal. What you have is a sub panel. With both 240 and 120 loads. It must be supplied with 4 conductors, not 3.
John
The Following 2 Users Say Thank You to jrclen For This Useful Post:
jbfan (11-02-2012), mpoulton (11-02-2012)
Tile install help/advice needed ASAP mcu Flooring 12 03-16-2012 06:41 PM
Answer needed asap!!!! Beaconresident Electrical 9 09-30-2011 05:01 PM
240v questions.... ITSANSS Electrical 16 05-11-2011 05:40 PM
power to "half" the house dogvila Electrical 8 07-13-2010 09:04 PM
Add more power to the house? (kinda long) tmtrebor Electrical 5 04-30-2010 03:19 PM
