Plug Housing For Plugs On Floor - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 02:47 PM   #1
hohadcr's Avatar
Rewards Points: 346
plug housing for plugs on floor
I have my office on a raised platform. A couple steps above the floor. The floor of the platform is just Chipboard. I can also easily access below the platform.
Now, I want to have plugs for my office devices such as computer and printer on the platform floor so all the power cords all go under the table.
What kind of plugs should I use? Should the plugs flush w/ the floor or on the surface of the platform floor taking into consideration of security and future cleaning ect?
hohadcr is offline   Reply With Quote
Old 10-17-2011, 04:57 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,990
The easiest way to handle this is to install the receptacles under the floor, and just cut holes in the floor and run the cables through the holes. This is actually a very common solution for wiring in data centers, where the space under the floor is used for cooling as well as cabling. It makes the installation very flexible, because you can easily cut more holes and move things around without rewiring the receptacles.
mpoulton is offline   Reply With Quote
Old 10-18-2011, 09:09 AM   #3
If you want to install plugs on the floor, please us an approved box. They are available at any home center. Examples look like:
brgmgb is offline   Reply With Quote
Old 10-18-2011, 09:54 AM   #4
Rewards Points: 3,130
I agree, but boy are they expensive. Because of the floor plan, I was afraid I was going to need a couple of these when I wired my log home, but the inspector let me slide. Not to say he let me use an unapproved item, but let me get off without any outlet.
Old 10-18-2011, 11:06 AM   #5
Rewards Points: 240
Use plastic adjustable floor boxes for wood floors. Like this one. http://www.carlon.com/Product_Adjust...lFloorBox.html
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Pet Sanctuary Needs Urine-proof, affordable floor which is not too hard. Pet Sanctuary Flooring 1 05-31-2011 04:53 PM
Floor damage from a 2nd floor bathroom toilet leak Tamber Plumbing 3 05-02-2011 11:10 PM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 05:42 AM
Garage floor drain plug oxicottin General DIY Discussions 2 07-26-2009 08:21 PM
