Plug Comes Out Of Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2007, 01:30 PM   #1
Plug comes out of wall
Hi
I have a plug recepacle that comes out of the wall when you pull a plug out. It seems like the drywall around it has loosened up and there isn't much to secure the box to. Are there any products or tricks to secure an outlet box to drywall when the opening is too big?
thanks
jackiesmom is offline   Reply With Quote
Old 05-24-2007, 02:32 PM   #2
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Hi, it depends on what you mean by too big and also what kind of box was in there in the first place. Boxes secure in different ways, "new work" boxes are designed for open walls and attach directly to the studs, they screw in and sometimes grab around the face of the studs with little claws. These should not come loose. "old work" boxes are designed to install without interior wall access. There are different methods used. One uses little sleeves that wrap around the box to secure against drywall. Others are plastic boxes that have little plastic tabs at the end of screws that as you turn the screws draw closer toward the wall and stand straight up eventually grabing the wall from behind like a clamp. If it is one of these, it may need to be tightened. IF it is one of the others, it may need to be replaced with one of these. You say you already have an electrician coming for the circuit tripping? You may want to ask about this as well.
J187 is offline   Reply With Quote
Old 05-30-2007, 10:08 PM   #3
box ears
Go to Lowe's or Home depot. buy a pair of box ears. Go home. Trip the breaker. Take off the cover plate. take the receptical out of the box, no need to remove the wires. push one box ear into the wall outside the box. adjust the box to the depth that you need and bend the two tabs completly over the edge of the box,. do the samre thing with the other ear, replace the receptical and cover plate, Throw the swirtch, problem solved.
jdoherty is offline   Reply With Quote
Running Electical plug behind wall burdman Electrical 2 04-20-2007 10:15 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
