Please Tell Me Whats Wrong With My Wiring Here - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2012, 12:42 AM   #1
please tell me whats wrong with my wiring here
Can someone please tell me where I went wrong wiring in this diagram? I tapped into a switched power wire to add a few lights in my room. The problem is that the wire I tapped into powers a flood light outside, and I didn't want the flood light on all day when I had the interior lights on. I didn't even think about this being an issue. So what I did, as seem in my little diagram is to add a switch. I ran the power to the switch and then a separate line to the light. Both lights work with the original switch on, but when I turn the new switch off, the breaker trips. Where did I go wrong?
c miller is offline   Reply With Quote
Old 09-16-2012, 12:45 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
It would help if you showed your connections.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 09-16-2012, 12:49 AM   #3
" Euro " electrician
frenchelectrican's Avatar
Were you aware this is a switched light circuit when you make the spices in the attic junction box ??
Second thing how you did wired up the new switch.
Third thing is you should done in first place is find a unswitched circuit and use that to tap off to the new luminaire and new switch box for the luminaries itself or extend the circuit from the wall recetaple to the new switch box and new luminaries you installed.
Merci,
Marc
Old 09-16-2012, 01:28 AM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
You tapped a switch leg and have no neutral in your junction box.
The Following User Says Thank You to Stubbie For This Useful Post:
andrew79 (09-16-2012)
Old 09-16-2012, 01:40 AM   #5
All like colors are connected. At the first junction box I used wire nuts on each of the same colors-there were 3 wires on each nut. At the switch I have both 14 an wires tied like colors together with a short wire going to the switch
Old 09-16-2012, 01:49 AM   #6
dmxtothemax's Avatar
Rewards Points: 5,102
Can you post a pic or drawing,
of the wiring to the switch,
that you have added ?
Clearly it is wired wrong !
dmxtothemax is online now   Reply With Quote
Old 09-16-2012, 07:33 AM   #7
electures's Avatar
You have a dead short as soon as you through the switch.
Old 09-16-2012, 07:40 AM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,872
WHAT does this mean??
I agree, you either tied into a switch loop or you created a dead short at teh new switch.
It would have helped if you did some reading up on this BEFORE you started. There are many good books at the home centers that go over the basics of wiring circuits like this.
Old 09-16-2012, 08:07 AM   #9
Rewards Points: 2,516
Is this what your setup looked like before you attempted to add a switch and xtra lights. I did not show ground wires for ease of drawing
hammerlane is offline   Reply With Quote
Old 09-16-2012, 08:13 AM   #10
Resi EC
Rewards Points: 252
A picture (as stated) would really help.
Since we are guessing, are you sure you installed a single pole switch, not a 3-way?
Had a friend call me, like was on ALL the time when he flipped the switch on it would trip, (long story short) he had both blacks tied to one screw (pig-tailed) and both whites tied to other screw.
Gac66610 is offline   Reply With Quote
Old 09-16-2012, 08:16 AM   #11
Since your description of what you did is not comprehendable I will take a shot in the dark. If your existing setup was like in my post above, all you had to do was this:
Again no grounds shown for ease of drawing
please tell me whats wrong with my wiring here-switched-power-flood-lite.jpg
Old 09-17-2012, 03:27 PM   #12
Thanks for this!!! This solved my problem. I realized the wiring to the switch was wrong, and I was trying to use a 3 way switch when the original switch on the wall was a single pole switch. Thanks for your help!
Knob & Tube Wiring? cbzdel Electrical 8 08-17-2012 07:33 AM
Older air compressor wiring help lash-1295 Electrical 91 12-23-2009 01:46 PM
Charred / melted wall receptacle, AL wiring in house creamaster Electrical 17 12-04-2009 05:47 PM
Sunset Basic Home Wiring cover is wrong? CareBear Electrical 3 09-03-2009 11:31 AM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
