Please Help With Turnstyle Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2008, 04:50 AM   #1
Please help with turnstyle switch?
I removed the whole cord with the switch included from an annoying traffic light,light.
I need to know if the blinking is controlled by the bulbs in that light,or the switch?
Or,if the blinking is controlled by yet something I didn't think of?
Fatalist is offline   Reply With Quote
Old 08-30-2008, 05:51 AM   #2
Whatamess
It may have a flasher built inside.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-30-2008, 08:37 AM   #3
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
Maybe has an internal timer with a couple relays.
Pudge565 is offline   Reply With Quote
Old 08-30-2008, 09:10 AM   #4
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
The traffic department is going to be upset with you.
John
jrclen is offline   Reply With Quote
Old 08-30-2008, 09:12 AM   #5
harhar
It's a novelty traffic signal.
So you guys think the flasher is not in my switch,then?
Old 08-30-2008, 11:04 AM   #6
Rewards Points: 246
Open it up and see. Who knows how it is designed. Pictures can help tremendously in these situations
Old 09-01-2008, 09:30 PM   #7
Eureka,I have light
I taped off the ground wire,and connected the switch wire,to the swag lamp.
I then plugged it in.I now have light.
Newer houses require the ground to be connected,but this one doesn't.
If I were to connect the ground,it would act as a lightning rod on this property,so black tape it is.
Old 09-02-2008, 08:00 AM   #8
Electrician
Where is this thing being installed? and IMO, your crazy to not install a EGC.
chris75 is offline   Reply With Quote
Old 09-02-2008, 09:32 AM   #9
jrclen's Avatar
Rewards Points: 514
Chris, I think the OP mixed up his threads. Sounds like this thread is now talking about this installation:
Please help with lighting project?
He is hanging a home made two wire fixture I think. In a living space with a non conductive floor this is pretty common. I have one above my chair as we speak. Of course, mine is UL listed.
I have no clue what his last 2 sentences mean.
John
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
