Old 10-14-2009, 12:34 PM   #1
Please help me find a special dimmer switch
I'm trying to find a 500 watt dimmer switch with two interruptors with the dimmer in the middle. Does anyone know where I would find one? Would Home Depot have something like this?
Thanks in advance for your help...Dan
Safeair1 is offline   Reply With Quote
Old 10-14-2009, 06:06 PM   #2
Residential Contractor
I may be confused by the terminology, but it sounds to me like you want to be able to control lighting from three locations, one being a dimmer switch.
If I am correct, this can be done with a 3-way switch, a 3-way dimmer, and a 4-way switch. The issue I imagine you may have is that wires called travelers must interconnect the 3 devices. If your wiring is in conduit and all three locations are piped together, this is fairly simple. If not, post further information.
rselectric1 is offline   Reply With Quote
Old 10-14-2009, 06:23 PM   #3
300zx's Avatar
Post
If i am reading correct you will need to take the single box out and put in a 2 gang cut in box then put 2 dimmers in
300zx is offline   Reply With Quote
Old 10-15-2009, 02:35 PM   #4
Electrical Contractor
Lutron makes a dual dimmer. Its only good for 300W on each leg. http://www.amazon.com/gp/product/B0016P0B20
ohmy is offline   Reply With Quote
Old 10-15-2009, 02:48 PM   #5
300zx's Avatar
I looked everywhere and could not find one
Tags
dimmers, electrical question, switches
Installing of SwitchLinc Dimmer (2476D) dlp_710 Electrical 8 08-07-2009 02:31 PM
Light doesn't turn on immediately on dimmer switch Michblaze02 Electrical 3 03-19-2009 06:14 AM
help w/ dimmer switch Mack V Electrical 5 02-15-2008 11:30 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 09:43 PM
